Multifunktionswerkzeuge
NEU
NEU
The Original All-Round Multi-Tool
  • Trusted All-Round Multi‑Tool performance.
  • Curated kit of metalworking essentials for cutting, drilling and precision tasks.
  • Pen‑shaped Flex Shaft Attachment (225) for greater control on detailed work.
Bausätze
99.83 EUR
Limited Metal Edition
Specifically curated, this kit brings together the essentials to create a practical metalwork set up. The kit includes two Metal Cutting Wheels (SC456), a Precision Drill Bit Set (628) that includes 7 high-grade steel bits in various sizes, the Flex Shaft Attachment (225) and a Multi Chuck (4486) for quick and easy accessory changes. The pen shaped Flex Shaft Attachment delivers greater control for detailed tasks, making it easier to work accurately on smaller or more intricate projects.
Dremel 3000 is the true icon of quick, compact and versatile Multi-Tools. Its corded design is built for precision across a wide range of applications, offering variable speed control from 10,000–35,000 RPM for carving, engraving, routing, cutting, sanding, grinding, sharpening, polishing and cleaning. Its soft grip construction reduces vibration for better handling during extended use, and it’s fully compatible with all Dremel Multi Tool accessories and attachments for maximum versatility.
Enter a Versatile Ecosystem
The Dremel 3000 is compatible with the full range of Dremel Multi Tool accessories and attachments. While this edition is designed for metal work, the tool can be easily adapted for variety of tasks by simply changing accessories and attachments. Dremel’s portfolio supports 150+ accessories for a variety of applications: cutting, drilling, engraving, carving, routing, sanding, grinding, sharpening, polishing and cleaning.
Variable Drehzahl von 10.000–33.000 1/min: komfortablere und bessere Werkzeugführung bei der Arbeit.
130 W-Motor – für optimale Leistung.
Softgrip: für weniger Vibrationen und bessere Handhabung.
Nenn-/Eingangsleistung
130 W
Spannung
0,55 kg
Tiefe
Leerlaufdrehzahl
10.000 35.000 1/min
Schnellwechselsystem
Schalldruck
77,1 dB(A)
Schallleistung
88,1 dB(A)
Vibrationen
12,8 m/s²
F0133000VJ
Benutzerhandbücher
Ihre Auswahl
Dremel 3000 mit 6 Zubehörteilen
Bausätze
Bestellnummer: F0133000JU
EAN-Code: 8710364078356
58.97 EUR
Produktdetails
Dremel 3000 mit 15 Zubehörteilen
Bausätze
Bestellnummer: F0133000JA
EAN-Code: 8710364060856
69.08 EUR
Produktdetails
Related Media DREMEL® 3000 Limited Edition 2026
Bausätze
Bestellnummer: F0133000WC
EAN-Code: 4053423067378
85.7 EUR
Produktdetails
Das Dremel 3000 Multifunktionswerkzeug mit 1 Aufsatz, 25 Zubehörteilen, einem Werkzeughalter und einem praktischen Koffer
Bausätze
Bestellnummer: F0133000JP
EAN-Code: 8710364074686
89.75 EUR
Produktdetails
Dremel 3000 2/25 Multi-Tool-Set mit verschiedenen Anbauteilen, einer biegsamen biegsamen Welle , einer Tragetasche und einigen Zubehörteilen
Bausätze
Bestellnummer: F0133000HA
EAN-Code: 8710364080823
107.22 EUR
Produktdetails
