Brosse en laiton 19 mm (535-2) 2 pièces
7.90 CHF*PVC TTC
Nettoyage / Polissage
For cleaning soft metals like gold, bronze or copper.
  • Ideal for cleaning and surface-finishing
  • Use on items made from gold, bronze, copper or brass
  • Use a brass brush to create a soft, satin or matte finish
7.90 CHF*
Tuyaux métalliques
Tôles
Métal tendre
Laiton
Acier durci
Or
Argent
Acier inoxydable
Fonte
Cuivre
tr/min
Perfect for cleaning flat surfaces and getting into hard-to-reach places, the versatile 3/4 In. (19.1 mm) diameter Brass Brushes are ideal for cleaning and surface polishing to create a soft, satin or matte finish. Non-sparking and softer than steel, the brushes are ideal for use on soft metals like gold, bronze, copper or brass. For optimal results, operate the brush at a maximum speed of 15,000 rpm and avoid applying excessive pressure to extend the accessory’s lifespan and performance.
Diamètre de la queue
Diamètre de fonctionnement
19,0 mm
Longueur de l'accessoire
44,0 mm
Matériau
Brosses en laiton
Forme
Brosse couronne
Utilisation du mandrin
Aucun mandrin nécessaire
19,0 mm
Vitesse maximale
15.000 tr/min
19,0 mm
Hauteur
44,0 mm
2
2
Outils multi-usage
Stylo+ DREMEL (2050-15)
Stylo+ DREMEL® (2050-10)
Bricolage
8710364070381
26150535JA
Dremel accessoire Brosse laiton 535-2
Détails de la fourniture
  • 2
  • Longueur de l'emballage, 1.3 cm
