NOVITÀ
NOVITÀ
The Original All-Round Multi-Tool
  • Trusted All-Round Multi‑Tool performance.
  • Curated kit of metalworking essentials for cutting, drilling and precision tasks.
  • Pen‑shaped Flex Shaft Attachment (225) for greater control on detailed work.
Limited Metal Edition
Specifically curated, this kit brings together the essentials to create a practical metalwork set up. The kit includes two Metal Cutting Wheels (SC456), a Precision Drill Bit Set (628) that includes 7 high-grade steel bits in various sizes, the Flex Shaft Attachment (225) and a Multi Chuck (4486) for quick and easy accessory changes. The pen shaped Flex Shaft Attachment delivers greater control for detailed tasks, making it easier to work accurately on smaller or more intricate projects.
Dremel 3000 is the true icon of quick, compact and versatile Multi-Tools. Its corded design is built for precision across a wide range of applications, offering variable speed control from 10,000–35,000 RPM for carving, engraving, routing, cutting, sanding, grinding, sharpening, polishing and cleaning. Its soft grip construction reduces vibration for better handling during extended use, and it’s fully compatible with all Dremel Multi Tool accessories and attachments for maximum versatility.
Enter a Versatile Ecosystem
The Dremel 3000 is compatible with the full range of Dremel Multi Tool accessories and attachments. While this edition is designed for metal work, the tool can be easily adapted for variety of tasks by simply changing accessories and attachments. Dremel’s portfolio supports 150+ accessories for a variety of applications: cutting, drilling, engraving, carving, routing, sanding, grinding, sharpening, polishing and cleaning.
Velocità variabile - 10.000–33.000 giri/min: migliore comodità e controllo durante l’utilizzo.
Potenza dissipata nominale
130 W
Tensione
0,55 kg
Profondità
Velocità senza carico
10.000 35.000 1/min
Pressione acustica
77,1 dB(A)
Potenza acustica
88,1 dB(A)
Vibrazioni
12,8 m/s²
4053423072938
F0133000VJ
Manuali utente
La tua selezione
Dremel 3000 con 6 accessori
Kit
Numero d`ordine: F0133000JU
Codice EAN: 8710364078356
SFr. 55.00*
Dettagli del prodotto
Dremel 3000 e 15 accessori
Kit
Numero d`ordine: F0133000JA
Codice EAN: 8710364060856
SFr. 63.00*
Il multiutensile Dremel 3000 con 1 complemento, 25 accessori, un supporto utensile e una custodia in plastica
Kit
Numero d`ordine: F0133000JP
Codice EAN: 8710364074686
SFr. 84.00*
Kit multiutensile Dremel 3000 2/25 presentato con vari complementi, un albero flessibile, una custodia per il trasporto e alcune punte accessorie
Kit
Numero d`ordine: F0133000HA
Codice EAN: 8710364080823
SFr. 102.00*
