Sägen
DREMEL® Blueprint wood fine finish blade (CS900)
NEU
Sägen
NEU
Your go to blade for smooth, clean, fine finish wood cuts.
  • Cuts cleanly while staying sharp over time.
  • Dense tooth design reduces tear-out for crisp, smooth edges.
  • Reliable performance across softwood, hardwood, and plywood.
Alle Variationen ansehen
16.99 EUR
Fine Finish Wood Blade
This blade is made for those moments when the final look really matters. Whether you’re cutting trim, prepping cabinetry pieces, or adding finishing touches to a project, it keeps splintering low and edges crisp. It’s a reliable choice for anyone who wants a clean result without sanding out a rough cut later.
Ultra Smooth Cutting Performance
The design focuses on surface quality. It delivers clean, fine finish cuts across softwood, hardwood, and plywood, helping you get a clean finish right from the saw. Perfect for decorative work, visible joints, or any cut where you want the surface to look refined-not ripped or frayed.
Blueprint Range Compatibility
The blade is designed to work seamlessly with the Dremel Blueprint Portable Saw Station and Compact Saw. No adjustments, just a proper fit and consistent performance. It’s made to feel intuitive and dependable so you can focus fully on your project.
Fine Tooth Design for Clean Edges
A dense, fine tooth layout helps reduce tear out and leaves you with smooth, even edges. It cuts cleanly while staying sharp over time, so you can rely on it through multiple projects without losing performance. It’s a great companion for anyone who values detail and finish quality.
Arbeitsdurchmesser
Verpackungsinhalt
2608847811
85,0 mm
1 Stück
  • Your go to blade for smooth, clean, fine finish wood cuts.
2608846431
85,0 mm
1 Stück
DREMEL® Blueprint Holz Kreissägeblatt 85 mm (CS500)
  • Das Zubehör deiner Wahl für Holzsägearbeiten
2608846430
85,0 mm
1 Stück
DREMEL® Blueprint Multi-Material-Sägeblatt (CS600)
  • Sägen in verschiedenen Materialien leicht gemacht
2615MS50JA
5 Stück
DREMEL® Moto-Saw Sägeblatt für seitliche Schnitte (MS50) 5 Stück
2615MS51JA
5 Stück
DREMEL® Moto-Saw Allzweck-Holzsägeblatt (MS51) 5 Stück
2615MS52JA
5 Stück
DREMEL® Moto-Saw Holzsägeblatt, fein (MS52) 5 Stück
2615MS53JA
5 Stück
DREMEL® Moto-Saw Metallsägeblatt (MS53) 5 Stück
Schaftdurchmesser
15,0 mm
Arbeitsdurchmesser
85,0 mm
Wolframkarbid
Form
Klinge
Höchstdrehzahl
6.000 1/min
Schnitttiefe
25 mm
Dremel Blueprint CS900 wood fine finish circular saw blade
Lieferdetails
  • 1 pc
  • Höhe des Produktkartons, 155 cm
  • Breite des Produktkartons, 115 cm
  • Bruttogewicht, 0,06 kg
16.99 EUR
