Carving/Engraving/Routing
115DM Carving bit (115DM)
115DM Carving bit
115DM Carving bit
115DM Carving bit 115DM Carving bit
Cylindrical-shaped Dremel Max carving bit for wood and more
  • Carving accessory with maximum durability and lasting performance for demanding DIY jobs that require precision
  • Coated with Titanium Nitride to last 2 times longer than the standard bit
  • Remove material with precision for applications like carving, engraving or freehand routing
  • Ideal for a wide range of materials like wood, plastics and soft metals
  • Contents: 2x Dremel® Max Carving Bit 7.8 mm (115DM)
£15.98* RRP incl. VAT
The heavy-duty Dremel Max Carving Bit 115DM is coated in Titanium Nitride to last 2 times longer than the standard, non-coated accessory.
What can you do with it?
Remove material with precision for applications like, carving, freehand routing, shaping and hollowing in a wide range of materials. Ideal for your carving and engraving projects in wood, plastic and soft metals such as aluminium, copper and brass.
How to use:
Let the accessory and your Dremel Multi-Tool do the work without forcing or pushing too hard. For an effective result, use the sides of the accessory head at an angle less than 90 degrees. Do you feel the accessory is chattering more than removing material? Turn up the RPM to have a smoother result. Have a look at the icon or the video to check out the result first, or grab a piece of scrap material before diving into your DIY project.
Expand your possibilities with these attachments: Flexible Shaft (225); Flex-Shaft Tool Holder (2222); Detailer's Grip Attachment (577); Multi-Vise (2500)
Recommended speed (RPM):
Aluminium 30.000
Brass 30.000
Copper 30.000
Hardwood 35.000
Softwood 20-25.000
Plastic 35.000
Steel 20-25.000
Example of usage
Technical details for 115DM Carving bit (115DM)
  • Veneered woods Veneered woods
  • Softwood Softwood
  • Leather Leather
  • Plywood Plywood
  • Laminates Laminates
  • Chipboard Chipboard
  • Brick Brick
  • Drywall/Plasterboard Drywall/Plasterboard
  • Aerated Concrete Aerated Concrete
  • Hardwood Hardwood
  • Soft Metal Soft Metal
  • Rubber Rubber
  • Plastic Plastic
  • Plexiglass Plexiglass
  • Carbon Carbon
Technical specifications
Shank diameter
Working diameter
7,9 mm
Accessory length
8,0 mm
8,0 mm
Height
Maximum RPM
Package Contents
2 pieces
Dremel MAX Accessories
Dremel MAX Accessories - Maximum Durability. Lasting Performance
Get more information about the complete program.
Variations
Delivery details: 115DM Carving bit (115DM)
Product box length, 5 cm
Product box height, 10 cm
Product box width, 2.5 cm
26150115DM
8710364082797
Recommended products:
DREMEL® 4000
£130.00* RRP incl. VAT
Multipurpose Set
£18.00* RRP incl. VAT
