Retired Products
Abrasive Point (516)
Retired Products
6.34 GBP
Sheet Metal
Metal pipes
Soft Metal
Brass
Hardened Steel
Gold
Silver
Stainless Steel
Cast iron
Copper
What can you do with it?
For finishing work and light deburring. For paint and rust removal without removing any of the base material. specially designed for working with conic and flat surfaces.
How to use?
Go for gentle strokes and monitor the material removal for the best results
Materials to use on:
Any kind of material
Recommended speeds:
Aluminum 20-35000 Brass 20-35000 Copper 20-35000 Hardwood 15-20000 Plastic 20-25000 Softwood 15-20000 Steel 30000
Package contents
Price
2615051632
1 piece
£8.30*
  • Bullet shaped abrasive point for deburring or paint removal, without removing the base material
2615821532
1 piece
£3.20*
Aluminum Oxide Grinding Stone 25,4 mm (8215)
  • Thin cylindrical shaped aluminium oxide grinding stone with the largest diameter.
26153322JA
3 pieces
£10.50*
Silicon Carbide Grinding Stone 3,2 mm (83322) 3 pieces
  • Small, bullet shaped, silicon carbide grinding stone.
Shank diameter
Working diameter
13,0 mm
Accessory length
37,0 mm
11,0 mm
11,0 mm
Height
Maximum RPM
20.000 1/min
Suitable Dremel devices
Retired Products
Multi-Tools
8710364015238
2615051632
Dremel accessory 516_Abrasive Point
Delivery details
  • Product box length, 1.5 cm
  • Product box height, 10 cm
  • Product box width, 5 cm
6.34 GBP
