Grinding/sharpening
Abrasive Point (516)
Bullet shaped abrasive point for deburring or paint removal, without removing the base material
£7.00*
RRP incl. VAT
What can you do with it?
For finishing work and light deburring. For paint and rust removal without removing any of the base material. specially designed for working with conic and flat surfaces.
How to use?
Go for gentle strokes and monitor the material removal for the best results
Materials to use on:
Any kind of material
Recommended speeds:
Aluminum 20-35000
Brass 20-35000
Copper 20-35000
Hardwood 15-20000
Plastic 20-25000
Softwood 15-20000
Steel 30000
Brass 20-35000
Copper 20-35000
Hardwood 15-20000
Plastic 20-25000
Softwood 15-20000
Steel 30000
Example of usage
Technical details for Abrasive Point (516)
Sheet Metal
Metal pipes
Soft Metal
Brass
Hardened Steel
Gold
Silver
Stainless Steel
Cast iron
Copper
Technical specifications
Shank diameter
Working diameter
13,0 mm
Accessory length
37,0 mm
11,0 mm
11,0 mm
Height
Maximum RPM
20.000 1/min
Package Contents
1 piece
Suitable Dremel devices
Retired Products
Multi-Tools
2615051632
8710364015238
Delivery details: Abrasive Point (516)
Product box length, 1.5 cm
Product box height, 10 cm
Product box width, 5 cm
2615051632
8710364015238
8710364015238
