Grinding/sharpening
Aluminum Oxide Grinding Stone 25,4 mm (8215)
Thin cylindrical shaped aluminium oxide grinding stone with the largest diameter.
£2.00*
RRP incl. VAT
What can you do with it?
For sharpening, deburring and general purpose grinding on most materials including stainless steel. E.g. sharpening lawn mower blades, screwdriver tips, knives, scissors, chisels and other cutting tools. Use to remove flash from metal castings, deburring any metal after cutting, smoothing welded joints, grinding off rivets and removing rust.
How to use?
Use the side of the accessory for the best finish at an angle.
Materials to use on:
The orange grinding stones are for metal-like, ferrous materials, like stainless steel, aluminium, brass, copper.
Recommended speeds (RPM):
Aluminum: 15.000
Brass: 15.000
Copper: 15.000
Example of usage
Technical details for Aluminum Oxide Grinding Stone 25,4 mm (8215)
Metal pipes
Sheet Metal
Soft Metal
Brass
Hardened Steel
Gold
Silver
Stainless Steel
Cast iron
Copper
Technical specifications
Shank diameter
Working diameter
25,4 mm
Accessory length
40,0 mm
11,0 mm
11,0 mm
Height
Maximum RPM
20.000 1/min
Package Contents
1 piece
Suitable Dremel devices
Retired Products
Multi-Tools
2615821532
8710364008148
Similar Accessories (6)
Delivery details: Aluminum Oxide Grinding Stone 25,4 mm (8215)
Product box length, 2 cm
Product box height, 10 cm
Product box width, 5 cm
2615821532
8710364008148
8710364008148
