Grinding / Sharpening
Aluminum Oxide Grinding Stone 3,4 mm (997-3) 3 pieces
Smallest cone shaped, aluminium oxide grinding stone with a flat tip for grinding materials like metal.
- Ideal for sharpening, deburring and extended general purpose grinding on most materials including stainless steel
- For use on metals, castings, welded joints, rivets and rust
- Specially designed for working with conic surfaces
Metal pipes
Sheet Metal
Soft Metal
Brass
Hardened Steel
Gold
Silver
Stainless Steel
Cast iron
Copper
What can you do with it?
For sharpening, deburring and general purpose grinding on most materials including stainless steel. E.g. sharpening lawn mower blades, screwdriver tips, knives, scissors, chisels and other cutting tools. Use to remove flash from metal castings, deburring any metal after cutting, smoothing welded joints, grinding off rivets and removing rust.
How to use?
Use the side of the accessory for the best finish at an angle.
Materials to use on:
The orange grinding stones are for metal-like, ferrous materials, like stainless steel, aluminium, brass, copper.
Recommended speeds:
Aluminum 15.000 Brass 15.000 Copper 15.000
- Smallest cone shaped, aluminium oxide grinding stone with a flat tip for grinding materials like metal.
Aluminum Oxide Grinding Stone 4,8 mm (8153-3) 3 pieces
- Smallest cylindrical shaped aluminium oxide grinding stone.
Aluminum Oxide Grinding Stone 15,9 mm (8193-2) 2 pieces
- Cylindrical shaped, aluminium oxide grinding stone with the largest diameter.
Aluminum Oxide Grinding Stone 25,4 mm (8215)
- Thin cylindrical shaped aluminium oxide grinding stone with the largest diameter.
Aluminum Oxide Grinding Stone 9,5 mm (932-3) 3 pieces
- Medium sized, cylindrical grinding stone. For grinding materials like metal.
Aluminum Oxide Grinding Stone 9,5 mm (952-3) 3 pieces
- Medium sized, cone shaped grinding stone. For grinding materials like metal.
Aluminum Oxide Grinding Stone 6,4 mm (953-3) 3 pieces
- Small sized, cone shaped grinding stone. For grinding materials like metal.
Suitable Dremel devices
Retired Products
Multi-Tools
- 3 pcs
- Product box length, 2 cm
- Product box height, 10 cm
- Product box width, 5 cm
