Grinding/sharpening
Aluminum Oxide Grinding Stone 6,4 mm (953)
Aluminum Oxide Grinding Stone 6,4 mm Aluminum Oxide Grinding Stone 6,4 mm
Small sized, cone shaped grinding stone. For grinding materials like metal.
£6.00* RRP incl. VAT
What can you do with it?
For sharpening, deburring and general purpose grinding on most materials including stainless steel. E.g. sharpening lawn mower blades, screwdriver tips, knives, scissors, chisels and other cutting tools. Use to remove flash from metal castings, deburring any metal after cutting, smoothing welded joints, grinding off rivets and removing rust.
How to use?
Use the side of the accessory for the best finish at an angle.
Materials to use on:
The orange grinding stones are for metal-like, ferrous materials, like stainless steel, aluminium, brass, copper.
Recommended speeds:
Aluminum 15000 Brass 15000 Copper 15000
Example of usage
Technical details for Aluminum Oxide Grinding Stone 6,4 mm (953)
  • Metal pipes Metal pipes
  • Sheet Metal Sheet Metal
  • Aluminium Aluminium
  • Soft Metal Soft Metal
  • Brass Brass
  • Gold Gold
  • Silver Silver
  • Cast iron Cast iron
  • Copper Copper
Technical specifications
Shank diameter
Working diameter
Accessory length
40,0 mm
6,0 mm
6,0 mm
Height
Maximum RPM
25.000 1/min
Package Contents
3 pieces
Delivery details: Aluminum Oxide Grinding Stone 6,4 mm (953)
Product box length, 1 cm
Product box height, 10 cm
Product box width, 5 cm
26150953JA
8710364044900
Recommended products:
Multipurpose Set
£18.00* RRP incl. VAT
