Cleaning / Polishing
Brass brush 19 mm (535-2) 2 pieces
For cleaning soft metals like gold, bronze or copper.
  • Ideal for cleaning and surface-finishing
  • Use on items made from gold, bronze, copper or brass
  • Use a brass brush to create a soft, satin or matte finish
9.7 GBP
Metal pipes
Sheet Metal
Soft Metal
Brass
Hardened Steel
Gold
Silver
Stainless Steel
Cast iron
Copper
Perfect for cleaning flat surfaces and getting into hard-to-reach places, the versatile 3/4 In. (19.1 mm) diameter Brass Brushes are ideal for cleaning and surface polishing to create a soft, satin or matte finish. Non-sparking and softer than steel, the brushes are ideal for use on soft metals like gold, bronze, copper or brass. For optimal results, operate the brush at a maximum speed of 15,000 rpm and avoid applying excessive pressure to extend the accessory’s lifespan and performance.
Shank diameter
Working diameter
19.0 mm
Accessory length
44.0 mm
Brass Brushes
Shape
Radial Brush
Mandrel use
No Mandrel Needed
19.0 mm
Maximum RPM
15,000 1/min
19.0 mm
Height
44.0 mm
2
2
Suitable Dremel devices
Multi-Tools
Retired Products
8710364070381
26150535JA
Dremel accessory Brass brush 535-2
Delivery details
  • 2
  • Product box length, 1.3 cm
  • Product box height, 10 cm
  • Product box width, 5 cm
9.7 GBP
