Cleaning/polishing
Bristle Brush 19 mm (403)
Bristle Brush 19 mm
Bristle Brush 19 mm
Bristle Brush 19 mm Bristle Brush 19 mm
For cleaning flat surfaces or grooves in materials like plastic or steel.
£5.00* RRP incl. VAT
Example of usage
Technical details for Bristle Brush 19 mm (403)
  • Metal pipes Metal pipes
  • Sheet Metal Sheet Metal
  • Soft Metal Soft Metal
  • Brass Brass
  • Gold Gold
  • Aluminium Aluminium
  • Silver Silver
  • Cast iron Cast iron
  • Copper Copper
Technical specifications
Shank diameter
Working diameter
19,0 mm
Accessory length
44,0 mm
19,0 mm
Maximum RPM
15.000 1/min
19,0 mm
Height
44,0 mm
Package Contents
2 pieces
Variations
Delivery details: Bristle Brush 19 mm (403)
Product box length, 1.3 cm
Product box height, 10 cm
Product box width, 5 cm
26150403JA
8710364070329
Recommended products:
DREMEL® 4200
DREMEL® 4000
100 Piece Multipurpose Modular Accessory Set
165 Piece Multipurpose Modular Accessory Set
DREMEL® 3000
£70.00* RRP incl. VAT
135 Piece Multipurpose Modular Accessory Set
DREMEL® 8100
Cleaning / Polishing Set
£18.00* RRP incl. VAT
DREMEL® 8200
