Cleaning / Polishing
Dremel (442)
Carbon Steel Brush 13 mm
Carbon Steel Brush 13 mm Carbon Steel Brush 13 mm Carbon Steel Brush 13 mm
For cleaning and removing rust of metal. Creates matte finish
£8.40* RRP incl. VAT
Example of usage
Technical details for Carbon Steel Brush 13 mm (442)
  • Metal pipes Metal pipes
  • Sheet Metal Sheet Metal
  • Soft Metal Soft Metal
  • Brass Brass
  • Gold Gold
  • Aluminium Aluminium
  • Silver Silver
  • Cast iron Cast iron
  • Copper Copper
Technical specifications
Shank diameter
Working diameter
13,0 mm
Accessory length
50,0 mm
Carbon Steel Brushes
Shape
Cup Brush
Mandrel use
No Mandrel Needed
15,0 mm
Maximum RPM
15.000 1/min
15,0 mm
Height
50,0 mm
Variations
Delivery details: Carbon Steel Brush 13 mm (442)
Product box length, 1.3 cm
Product box height, 10 cm
Product box width, 5 cm
26150442JA
8710364070350
Recommended products:
Cleaning / Polishing Set
£19.00* RRP incl. VAT
