Cleaning / Polishing
Carbon Steel Brush 19 mm (428) 2 pieces
For cleaning and removing rust of metal. Creates matte finish
  • Ideal for cleaning and removing rust and corrosion from items made of brass, copper, gold or other soft ferrous metals-such as tools, door knobs, automobile parts and electrical contacts
  • You can also use wire brushes to create an artistic effect on coarse-grained wood
  • Its shape makes it well suited for cleaning flat surfaces
See all variations
8.7 GBP
Metal pipes
Sheet Metal
Soft Metal
Brass
Hardened Steel
Gold
Silver
Stainless Steel
Cast iron
Copper
Working diameter
Maximum RPM
Package contents
Price
26150428JA
19.0 mm
15,000 1/min
2 pieces
£8.50*
  • For cleaning and removing rust of metal. Creates matte finish
26150443JA
3.2 mm
15,000 1/min
3 pieces
£11.50*
Carbon Steel Brush 3,2 mm (443-3) 3 pieces
26150442JA
13.0 mm
15,000 1/min
2 pieces
£8.50*
Carbon Steel Brush 13 mm (442) 2 pieces
Shank diameter
Working diameter
19.0 mm
Accessory length
44.0 mm
Carbon Steel Brushes
Shape
Radial Brush
Mandrel use
No Mandrel Needed
19.0 mm
Maximum RPM
15,000 1/min
19.0 mm
Height
44.0 mm
2
2
Suitable Dremel devices
Retired Products
Multi-Tools
8710364070343
26150428JA
Dremel accessory  428_Carbon Steel Brush 19 mm
Delivery details
  • Product box length, 1.3 cm
  • Product box height, 10 cm
  • Product box width, 5 cm
8.7 GBP
