Cleaning/polishing
Carbon Steel Brush 19 mm (428)
Carbon Steel Brush 19 mm Carbon Steel Brush 19 mm
For cleaning and removing rust of metal. Creates matte finish
£7.00* RRP incl. VAT
Example of usage
Technical details for Carbon Steel Brush 19 mm (428)
  • Metal pipes Metal pipes
  • Sheet Metal Sheet Metal
  • Soft Metal Soft Metal
  • Brass Brass
  • Gold Gold
  • Aluminium Aluminium
  • Silver Silver
  • Cast iron Cast iron
  • Copper Copper
Technical specifications
Shank diameter
Working diameter
19,0 mm
Accessory length
44,0 mm
19,0 mm
Maximum RPM
15.000 1/min
19,0 mm
Height
44,0 mm
Package Contents
2 pieces
Variations
Delivery details: Carbon Steel Brush 19 mm (428)
Product box length, 1.3 cm
Product box height, 10 cm
Product box width, 5 cm
26150428JA
8710364070343
Recommended products:
DREMEL® 4200
DREMEL® 4000
100 Piece Multipurpose Modular Accessory Set
165 Piece Multipurpose Modular Accessory Set
135 Piece Multipurpose Modular Accessory Set
DREMEL® 3000
£70.00* RRP incl. VAT
DREMEL® 8100
DREMEL® 8200
Cleaning / Polishing Set
£18.00* RRP incl. VAT
