Carving/Engraving/Routing
Carving Bit (117DM)
Curve-shaped Dremel Max carving bit for wood and more
Delivers maximum durability and lasting performance for your demanding and extensive DIY projects
Coated with Titanium Nitride to last 2 times longer than the standard bit
Remove material with precision for applications like carving, engraving or freehand routing
Ideal for a wide range of materials like wood, plastics and soft metals
Contents: 2x Dremel® Max Carving Bit 6.4 mm (117DM)
£18.58*
RRP incl. VAT
The Dremel® Max accessory line, designed by our engineers, provides maximum durability and lasting performance. The heavy-duty Dremel Max Carving Bit 117DM is coated in Titanium Nitride to last 2 times longer than the standard, non-coated accessory.
What can you do with it?
Remove material with precision for applications like, carving, freehand routing, shaping and engraving in a wide range of materials. Ideal for your carving and engraving projects in wood, plastic and soft metals such as aluminium, copper and brass.
How to use:
Let the accessory and your Dremel Multi-Tool do the work without forcing or pushing too hard. For an effective result, use the sides of the accessory head at an angle less than 90 degrees. Do you feel the accessory is chattering more than removing material? Turn up the RPM to have a smoother result. Have a look at the icon or the video to check out the result first, or grab a piece of scrap material before diving into your DIY project.
Expand your possibilities with these attachments: Flexible Shaft (225); Flex-Shaft Tool Holder (2222); Detailer's Grip Attachment (577); Multi-Vise (2500)
Recommended speed (RPM):
Aluminium 30.000
Brass 30.000
Copper 30.000
Hardwood 35.000
Softwood 20-25.000
Plastic 35.000
Steel 20-25.000
Brass 30.000
Copper 30.000
Hardwood 35.000
Softwood 20-25.000
Plastic 35.000
Steel 20-25.000
Example of usage
Technical details for Carving Bit (117DM)
Veneered woods
Softwood
Leather
Plywood
Laminates
Chipboard
Brick
Drywall/Plasterboard
Aerated Concrete
Hardwood
Soft Metal
Rubber
Plastic
Plexiglass
Carbon
Technical specifications
Shank diameter
Working diameter
Accessory length
6,0 mm
6,0 mm
Height
Maximum RPM
Package Contents
2 pieces
Delivery details: Carving Bit (117DM)
Product box length, 5 cm
Product box height, 10 cm
Product box width, 1 cm
26150117DM
8710364082803
8710364082803
