Grinding / Sharpening
Chainsaw Sharpening Grinding Stone 4,5 mm (457) 3 pieces
Chainsaw chain
What can you do with it?
Sharpen the tooth of the chain
How to use?
When sharpening a chain saw, sharpen all of the teeth going in one direction, then with the saw in the same position, line the tool up with the second 30° mark and sharpen the teeth that run in the opposing direction. Always try to do the same tooth two or three passes across each tooth. Use the spacers for the best result. They are used to move the pink or orange stones away from the attachment – so they don’t contact the attachment during operation. The pink stone (the largest) requires both spacers. The orange stone (the middle size) requires one spacer. The blue/grey stone does not require any spacers.
Materials to use on:
Chains of chainsaw
Recommended speeds:
Chainsaw Blade 30000
- Second to smallest chainsaw sharpening bit.
Chainsaw Sharpening Grinding Stone 4 mm (453-3) 3 pieces
- Smallest chainsaw sharpening bit. Does not require spacers
Chainsaw Sharpening Grinding Stone 4,8 mm (454-3) 3 pieces
- Second to biggest chainsaw sharpening bit. Requires one spacer
Chainsaw Sharpening Grinding Stone 5,6 mm (455-3) 3 pieces
- Biggest chainsaw sharpening bit. Requires the use of both spacers
Suitable Dremel devices
Retired Products
Multi-Tools
- Product box length, 1 cm
- Product box height, 10 cm
- Product box width, 5 cm
