Grinding / Sharpening
Dremel (454)
Second to biggest chainsaw sharpening bit. Requires one spacer
£7.90*
RRP incl. VAT
What can you do with it?
Sharpen the tooth of the chain.
How to use?
When sharpening a chain saw, sharpen all of the teeth going in one direction, then with the saw in the same position, line the tool up with the second 30° mark and sharpen the teeth that run in the opposing direction. Always try to do the same tooth two or three passes across each tooth. Use the spacers for the best result. They are used to move the pink or orange stones away from the attachment – so they don’t contact the attachment during operation. The pink stone (the largest) requires both spacers. The orange stone (the middle size) requires one spacer. The blue/grey stone does not require any spacers.
Materials to use on:
Chains of chainsaw.
Recommended speeds:
Chainsaw Blade 30000
Example of usage
Technical details for Chainsaw Sharpening Grinding Stone 4,8 mm (454)
- Chainsaw chain
- RPM
- Attachment
Technical specifications
Shank diameter
Working diameter
4,8 mm
Accessory length
50,0 mm
Aluminum Oxide
Shape
Cylinder
Mandrel use
No Mandrel Needed
5,0 mm
5,0 mm
Height
Maximum RPM
30.000 1/min
Suitable Dremel devices
Retired Products
Multi-Tools
26150454JA
8710364044993
Delivery details: Chainsaw Sharpening Grinding Stone 4,8 mm (454)
Product box length, 1 cm
Product box height, 10 cm
Product box width, 5 cm
26150454JA
8710364044993
8710364044993
