Collets / Mandrels / Miscellaneous
Collets (3,2 mm) including a collet nut (4485)
Improve the grip for bits in our Multi-Tool line
- Provides the optimal grip for a wide range of bits offered for our Multi-Tool line
- The collet features small identification rings around its shank
- The rings correspond with the size of the collet
Improve the grip for bits in our Multi-Tool line with the Dremel collet set. With the 480, 481, 482, 483 collets, plus a quick-change collet nut, you can easily use a wide range of bits. This set of Dremel accessories contains 1 collet nut and 4 different sizes of collets: 0.8 mm, 1.6 mm, 2.4 mm and 3.2 mm diameter. Maximum recommended speed is 35.000 RPM. For use with all rotary tools except discontinued models 1, 2, and series 1 or earlier of discontinued models 260, 270 and 280.
Suitable Dremel devices
Retired Products
Multi-Tools
- 1 collet nut and 4 collets (0,8 / 1,6 / 2,4 / 3,2 mm)
- Product box length, 1.3 cm
- Product box height, 10 cm
- Product box width, 5 cm
