Cutting
Cut-Off Wheel 32 mm (540)
Cut-Off Wheel 32 mm
Cut-Off Wheel 32 mm
Cut-Off Wheel 32 mm Cut-Off Wheel 32 mm
For straight cuts in metal
£3.00* RRP incl. VAT
What can you do with it?
Good for slicing, making straight cuts and slots in all kinds of metal, like hardened steel, sheets metal or aluminum.
Easily cut bolts, or make slots in rusted and/or stripped bolts / screws for removal with a screwdriver.
How to use?
Use with 402 Mandrel: unscrew the top screw on the mandrel using the wrench, put the screw through the middle hole of the disk and screw it back on the mandrel.
If using the metal cutting wheels, cut on high speed – use light pressure. The wheels will last longer and cut faster if light pressure is used rather than heavy pressure and there is less risk of breaking it.
Since these disks are abrasive, the diameter of the wheel is going to wear away. If the wheel becomes too small to execute the cut, stop the cut and replace the wheel.
When using a cut-off wheel, we recommend using a two handed golf like grip to hold and guide the tool and go for a right angle. If you angle the wheel in the cut, the wheel will probably break.
Materials to use on
This cut-off disk can be used on different metal types, like aluminum, copper, cast iron. But also for short cuts in plastic or brick.
On materials like a galvanized metal (Ductwork) or hardened steel, it’s best to use reinforced cut-off wheel (426)
Recommended speed
Aluminium 35000
Brass 35000
Copper 35000
Plastic 10-15000
Steel 35000
Example of usage
Technical details for Cut-Off Wheel 32 mm (540)
  • Glass fibre reinforced plastics Glass fibre reinforced plastics
  • Brick Brick
  • Marble Marble
  • Drywall/Plasterboard Drywall/Plasterboard
  • Aerated Concrete Aerated Concrete
  • Soft Metal Soft Metal
  • Brass Brass
  • Gold Gold
  • Aluminium Aluminium
  • Silver Silver
  • Cast iron Cast iron
  • Copper Copper
  • Plastic Plastic
  • Mandrel Mandrel
Technical specifications
Shank diameter
Working diameter
32,0 mm
Max working depth
14,0 mm
32,0 mm
Maximum RPM
32,0 mm
Height
1,0 mm
Package Contents
5 pieces
Variations
Delivery details: Cut-Off Wheel 32 mm (540)
Product box length, 1 cm
Product box height, 10 cm
Product box width, 5 cm
2615054032
8710364010516
Recommended products:
Cutting Set
£19.00* RRP incl. VAT
