Cutting
Cutting/Shaping Wheel 25,4 mm (542)
Cutting
Sandwich material
Veneered woods
Softwood
Hardwood
Plywood
Laminates
Chipboard
Fiberboard
What can you do with it?
Wood Cutting Wheels are both carbide cutting wheels for slicing, cutting and shaping on woods and laminates. Ideal for short cuts in wooden floors to make room for e.g. heating pipes or electronics or model making. The carbide coating makes this wheel very durable.
How to use?
Cutting wheels only work on their edge.
We recommend using a (two-handed) golf grip when using this accessory, and using the right angle attachment when a cut is hard to reach. To keep the disc life as long as possible, do not apply excessive pressure and do not exceed the RPM limits.
Materials to use on
This cut-off disk can be used on different wood types, like chipboard, hardwood, softwood, laminate, fiberboard, or even on plastics and laminates. Do not use them on metals.
Recommended speed
Hardwood 20.000-35.000 RPM Softwood 20.000-35.000 RPM Plastic: 10.000-15.000 RPM
- With carbide coating for cutting wood and laminate (Not metal)
Cut-Off Wheel 32 mm (540-5) 5 pieces
- For straight cuts in metal
Heavy Duty Cut-Off Wheel 24 mm (420) 20 pieces
- For tougher cutting in metals, like hardened steel
Suitable Dremel devices
Retired Products
Multi-Tools
- Product box length, 1.3 cm
- Product box height, 10 cm
- Product box width, 5 cm
