Carving / Engraving
Diamond Wheel Point 2,0 mm (7134-2) 2 pieces
Carving / Engraving
Thin flat head diamond bit, for detailed engraving in hard materials
- For fine detail work, cutting, engraving, carving, touch-up and finishing
- Use on wood, jade, ceramic, glass, hardened steel, semi-precious stones and other hard materials
- Removes material quickly and easily
See all variations
17.5 GBP
Carbon
Leather
Rubber
Plastic
Brick
Soft Metal
Softwood
Hardwood
Glass
Copper
Silver
Gold
Brass
Ceramic
Porcelain
Shank diameter
Working diameter
Accessory length
Package contents
Price
26157134JA
2.0 mm
46.0 mm
2 pieces
£17.00*
- Thin flat head diamond bit, for detailed engraving in hard materials
Order number26157134JA
EAN-Code8710364044863
26157103JA
2.0 mm
45.0 mm
2 pieces
£17.00*
Diamond Wheel Point 2 mm (7103-2) 2 pieces
- Smallest ball shaped diamond bit, for engraving in hard material
Order number26157103JA
EAN-Code8710364044832
26157105JA
4.4 mm
46.0 mm
2 pieces
£24.50*
Diamond Wheel Point 4,4 mm (7105-2) 2 pieces
- Biggest ball shaped diamond bit, for engraving in hard material
Order number26157105JA
EAN-Code8710364044849
26157122JA
2.4 mm
46.0 mm
2 pieces
£15.00*
Diamond Wheel Point 2,4 mm (7122-2) 2 pieces
- Small cylindrical shaped diamond bit, for engraving in hard materials
Order number26157122JA
EAN-Code8710364044856
26157144JA
2.4 mm
46.0 mm
2 pieces
£16.00*
Diamond Wheel Point 2,4 mm (7144-2) 2 pieces
- Conical / pointed head diamond bit, for detailed engraving in hard materials
Order number26157144JA
EAN-Code8710364044870
Shank diameter
Working diameter
2.0 mm
Accessory length
46.0 mm
304 Stainless Steel
Shape
Flat Head
Mandrel use
No Mandrel Needed
3.0 mm
3.0 mm
Height
46.0 mm
Maximum RPM
25,000 1/min
2
2
Suitable Dremel devices
Retired Products
Multi-Tools
8710364044863
26157134JA
EAN Code8710364044863
Delivery details- 2 pcs
- Product box length, 5 cm
- Product box height, 10 cm
- Product box width, 1.3 cm
17.5 GBP
