Carving / Engraving
Dremel (7105)
Diamond Wheel Point 4,4 mm
Diamond Wheel Point 4,4 mm Diamond Wheel Point 4,4 mm Diamond Wheel Point 4,4 mm
Biggest ball shaped diamond bit, for engraving in hard material
£21.20* RRP incl. VAT
Example of usage
Technical details for Diamond Wheel Point 4,4 mm (7105)
  • Carbon Carbon
  • Leather Leather
  • Rubber Rubber
  • Plastic Plastic
  • Brick Brick
  • Soft Metal Soft Metal
  • Softwood Softwood
  • Hardwood Hardwood
  • Glass Glass
  • Copper Copper
  • Silver Silver
  • Gold Gold
  • Brass Brass
  • Ceramic Ceramic
  • Porcelain Porcelain
Technical specifications
Shank diameter
2.44 mm
Working diameter
4,4 mm
Accessory length
46,0 mm
304 Stainless Steel
Shape
Ball
Mandrel use
No Mandrel Needed
4,0 mm
4,0 mm
Height
46,0 mm
Maximum RPM
25.000 1/min
Variations
Delivery details: Diamond Wheel Point 4,4 mm (7105)
Product box length, 5 cm
Product box height, 10 cm
Product box width, 1.3 cm
26157105JA
8710364044849
