Corded Tools
Multi-Tool – Precise. Compact. Easy-to-use.
Two-speed simplicity: easy to handle when you’re new to DIY’ing
Endless uses: Engrave, carve, polish, clean, rout, cut, sand, grind and sharpen with just one tool
Get into tight spaces easily
5 accessories included so you can start working on your project straight away
2 year warranty
The Dremel 200-series is the ideal Multi-Tool to get started with Dremel. It's easy and comfortable the use and offers trusted Dremel quality and reliability at an affordable pricepoint. The tool is compatible with all accessories and attachments, and with the enclosed accessories for sanding, metal cutting and grinding the user can start working with Dremel immediately.
Technical details for DREMEL® 200 Series (200-5)
Technical specifications
Rated power input
125 W
Voltage
Weight
0,55 kg
18.5 cm
Depth
No load speed
15.000 - 35.000 1/min
Battery technology
No load speed (3)
Speed setting
Dual Speed
Accessory quick change system
No
Precision tip
Dual temperature
Removable cord
Drip control
Sound pressure
74,5 dB(A)
Sound power
85,5 dB(A)
Vibration
3,8 - 5,1 m/s²
Included accessories (5)
Delivery details: DREMEL® 200 Series (200-5)
Dremel 200 Series
5 high quality Dremel accessories
Instruction manual
Product box length, 7.7 cm
Product box height, 25 cm
Product box width, 15.6 cm
Gross weight, 0,92 kg
F0130200JB
8710364049684
8710364049684
