Corded Tools
DREMEL® 300 Series (300-25 Hobby)
The Dremel 300 series is the most popular corded Multi-Tool and perfect for projects that require more and long lasting power. It has fully variable speed settings to match your hobby application and it fits perfectly in your hand because of its ergonomic design. Use the Dremel Multi-Tool accessories for decorative projects like engraving pots, jewellery making, customizing furniture and also woodworking. There is truly no limit on the amount of projects you can do with this versatile Multi-Tool.
Technical details for DREMEL® 300 Series (300-25 Hobby)
Technical specifications
Rated power input
125 W
Voltage
Weight
0,55 kg
No load speed
10.000 - 33.000 1/min
No load speed (3)
Precision tip
Dual temperature
Removable cord
Drip control
Sound pressure
69 dB(A)
Sound power
80 dB(A)
Vibration
Included Accessories (16)
Overview of prices and Kit content
DREMEL® 300 Series (300-1/55)
Order number: F0130300JE
EAN Code: 8710364030521
Dremel 300 Series
55 high quality Dremel accessories in Mini Accessory Case
High quality Flex Shaft
Inspiring information DVD
Instruction manual
Spacious and sturdy storage case
Gross weight, 2,38 kg
DREMEL® 300 Series (300-30)
Order number: F0130300MR
EAN Code: 8710364046393
Dremel 300 Series
30 high quality Dremel accessories
Instruction manual
Soft bag
Gross weight, 1,22 kg
Order number: F0130300NL
EAN Code: 8710364048656
Dremel 300 Series
25 high quality Dremel accessories
Creative engraving templates
Instruction manual
Soft bag
Gross weight, 1,18 kg
