Retired Products
DREMEL® 300 Series (300-25 Hobby)
Retired Products
47.29 GBP
The Dremel 300 series is the most popular corded Multi-Tool and perfect for projects that require more and long lasting power. It has fully variable speed settings to match your hobby application and it fits perfectly in your hand because of its ergonomic design. Use the Dremel Multi-Tool accessories for decorative projects like engraving pots, jewellery making, customizing furniture and also woodworking. There is truly no limit on the amount of projects you can do with this versatile Multi-Tool.
Rated power input
125 W
Voltage
Weight
0.55 kg
No load speed
10.000 - 33.000 1/min
No load speed (3)
Sound pressure
69 dB(A)
Sound power
80 dB(A)
Vibration
8710364048656
F0130300NL
User Manuals
Your Selection
Dremel Multi-Tool 300 series with plastic grey case and the carton box
DREMEL® 300 Series (300-1/55)
Order number: F0130300JE
EAN Code: 8710364030521
66.37 GBP
Product details
Dremel Multi-Tool 300 series with 30 accessories and a blue zipper case
DREMEL® 300 Series (300-30)
Order number: F0130300MR
EAN Code: 8710364046393
45.6 GBP
Product details
