Corded Tools
Multi-Tool – Quick. Compact. All-round.
For all of your precision DIY projects: carve, engrave, rout, cut, sand, grind, sharpen, polish and clean
Work on your projects for extended periods of time
EZ Twist: Switch between applications within 1 or more projects easily
Multiple storage possibilities: packed in a sturdy case, the kit comes with a tool holder to mount the tool on the wall and allows for easy wrapping of the cord
2 year warranty
This kit includes the Dremel 3000 Multi-Tool, the high quality Dremel Flexible Shaft and 25 genuine Dremel accessories including EZ SpeedClic. All this is packed in a neatly organised case that includes a removable accessory tray and a tool holder which can be fixed to the wall and allows for easy wrapping of the tool's cord. This is a high value kit, offering you great value for money.
Example of usage
Technical details for DREMEL® 3000 (3000-1/25 EZ)
Technical specifications
Rated power input
130 W
Voltage
Weight
0,55 kg
Depth
No load speed
10.000 33.000 1/min
Battery technology
Speed setting
Variable
Accessory quick change system
Precision tip
Dual temperature
Removable cord
Drip control
Sound pressure
77,1 dB(A)
Sound power
88,1 dB(A)
Vibration
12,8 m/s²
Included accessories (25)
Overview of prices and delivery details
Order number: F0133000JB
EAN Code: 8710364060863
£55.00
See delivery details
Dremel 3000
15 high quality Dremel accessories
Instruction manual
Soft bag
Product box length, 18 cm
Product box height, 33.5 cm
Product box width, 7.4 cm
Gross weight, 1,13 kg
Order number: F0133000JR
EAN Code: 8710364074693
£80.00
Dremel 3000
25 high quality Dremel accessories (including EZ SpeedClic accessories)
Flexshaft attachment (225)
Instruction manual
Spacious and sturdy storage case with a removable accessory tray
Unique tool holder included for easy storage of your tool with your project
Product box length, 39.2 cm
Product box height, 10 cm
Product box width, 26.6 cm
Gross weight, 2,43 kg
Order number: F0133000HB
EAN Code: 8710364080830
£88.00
Dremel 3000
26 high quality Dremel accessories (including EZ SpeedClic accessories)
Multipupose cutting guide attachment
Storage bag
Quick start guide
Test materials
Product box length, 25.7 cm
Product box height, 28.5 cm
Product box width, 8.6 cm
