Corded Tools
The Dremel 3000 is the most popular corded Multi-Tool and perfect for projects that require more and long lasting power. It has fully variable speed settings to match your hobby application and it fits perfectly in your hand because of its ergonomic design. Use the Dremel Multi-Tool accessories for decorative projects like engraving pots, jewellery making, customizing furniture and also woodworking. There is truly no limit on the amount of projects you can do with this versatile Multi-Tool.
Technical details for DREMEL® 3000 (3000-1/25 Hobby)
Technical specifications
Rated power input
130 W
Voltage
Weight
0,55 kg
No load speed
10.000 33.000 1/min
Battery technology
Speed setting
Variable
Accessory quick change system
Precision tip
Dual temperature
Removable cord
Drip control
Sound pressure
77,4 dB(A)
Sound power
88,4 dB(A)
Vibration
2,4 - 5,4 m/s²
Included Accessories (16)
Overview of prices and Kit content
Order number: F0133000JH
EAN Code: 8710364067312
Dremel 3000
Detailer's Grip Attachment (577)
25 high quality Dremel accessories
Instruction manual
Soft bag
Product box length, 11 cm
Product box height, 32.5 cm
Product box width, 15.5 cm
Gross weight, 1,08 kg
Order number: F0133000LR
EAN Code: 8710364074471
Dremel 3000
55 high quality Dremel accessories (including EZ SpeedClic)
Flexible Shaft (225)
Cutting Guide attachment (565)
Shaping Platform Attachment (576)
Spacious and sturdy storage case
Instruction manual
Product box length, 39.5 cm
Product box height, 15.5 cm
Product box width, 18 cm
Gross weight, 2,11 kg
DREMEL® 3000 3 Star Kit (3000-05)
Order number: F0133000ME
EAN Code: 8710364077342
DREMEL® 3000
Unique tool holder included for easy storage of your tool with your project
Instruction Manual
Product box length, 30.5 cm
Product box height, 16.2 cm
Product box width, 8.8 cm
Gross weight, 1,07 kg
DREMEL® 3000 4 Star Kit (3000-3/55)
Order number: F0133000MJ
EAN Code: 8710364077380
DREMEL® 3000
Line & Circle Cutter (678)
Practical Dremel plastic tool box
Instruction Manual
Product box length, 38.5 cm
Product box height, 13.3 cm
Product box width, 17.5 cm
Gross weight, 2,23 kg
DREMEL® 3000 5 Star Kit (3000-5/75)
Order number: F0133000MP
EAN Code: 8710364077427
DREMEL® 3000
75 high quality Dremel accessories (including EZ SpeedClic)
Shaping Platform attachment (576)
Detailer's Grip attachment (577)
Line & Circle Cutter attachment (678)
Aluminum carry case
Instruction Manual
Product box length, 36.8 cm
Product box height, 18.7 cm
Product box width, 23.3 cm
Gross weight, 3,36 kg
DREMEL® 3000 (3000-05X)
Order number: F0133000NB
EAN Code: 8710364079643
DREMEL® 3000
Instruction Manual
Product box length, 8.8 cm
Product box height, 16 cm
Product box width, 30.5 cm
DREMEL® 3000 (3000-5/75X)
Order number: F0133000NL
EAN Code: 8710364079728
Dremel 3000
Aluminum carry case
Instruction Manual
Product box length, 23.3 cm
Product box height, 18.6 cm
Product box width, 36.5 cm
Gross weight, 3,23 kg
DREMEL® 3000 Derby Kit (3000 3/45)
Order number: F0133000TM
EAN Code: 8710364076383
DREMEL® 3000
Instruction Manual
DREMEL® 3000 (3000-1/25)
Order number: F0133000JE
EAN Code: 8710364060894
£70.00
Dremel 3000
25 high quality Dremel accessories (including EZ SpeedClic accessories)
High quality Flex Shaft
Instruction manual
Product box length, 20.7 cm
Product box height, 11 cm
Product box width, 34 cm
Gross weight, 1,98 kg
Order number: F0133000LV
EAN Code: 8710364074518
£80.00
Dremel 3000
70 high quality Dremel accessories (including EZ SpeedClic)
Comfort Guard attachment (550)
Aluminum carry case
Instruction Manual
Product box length, 36.5 cm
Gross weight, 3,22 kg
Order number: F0133000LL
EAN Code: 8710364074433
£100.00
Dremel 3000
Instruction manual
Product box length, 25 cm
Product box width, 7.7 cm
Gross weight, 0,89 kg
DREMEL® 3000 (3000-2/55)
Order number: F0133000NF
EAN Code: 8710364079681
£150.00
DREMEL® 3000
Flexshaft attachment (225)
Spacious and sturdy storage case with a removable accessory tray
Product box length, 17.5 cm
Product box width, 39 cm
Gross weight, 2,36 kg
DREMEL® 3000 Home Repair Project Kit (3000-3/105)
Order number: F0133000LE
EAN Code: 8710364072217
£200.00
Dremel 3000
105 high quality Dremel accessories (including EZ SpeedClic)
Home Renovation Project Booklet
Instruction Manual
Soft bag
Product box length, 22 cm
Product box height, 36.6 cm
Product box width, 10.9 cm
Gross weight, 1,84 kg
