Corded Tools
Powerful all-rounder multi-tool - Get your DIY design piece done from start to finish with just one tool
Can be used with all Dremel multi-tool accessories and most attachments
Easily switch between light-duty and more powerful DIY tasks: engrave, carve, cut, polish, clean, sand and more
The variable speed settings supported with a wide range of accessories included enables you to craft with various materials
Precise finishing ensured with the included Cutting Guide and Flexible Shaft attachment for your creative DIY project
The Dremel 3000 is the versatile all-rounder multi-tool that gets you from start to finish. Perfect for DIY projects that require powerful and precise light duty finishing applied on various materials. Swap applications using the 25 accessories in no time: from carving, engraving, sanding, polishing to cutting and more. Together with the included Dremel Cutting Guide and Flexible Shaft the kit allows you to achieve neat results with ease.
Example of usage
Technical details for DREMEL® 3000 (3000-2/25)
Technical specifications
Rated power input
130 W
Voltage
Weight
0,55 kg
Depth
No load speed
10.000 33.000 1/min
Battery technology
Speed setting
Variable
Accessory quick change system
Precision tip
Dual temperature
Removable cord
Drip control
Sound pressure
77,1 dB(A)
Sound power
88,1 dB(A)
Vibration
12,8 m/s²
Included Accessories (22)
Overview of prices and Kit content
Order number: F0133000JB
EAN Code: 8710364060863
£55.00
See Kit content
Dremel 3000
15 high quality Dremel accessories
Instruction manual
Soft bag
Product box length, 18 cm
Product box height, 33.5 cm
Product box width, 7.4 cm
Gross weight, 1,13 kg
Order number: F0133000JR
EAN Code: 8710364074693
£80.00
See Kit content
Dremel 3000
25 high quality Dremel accessories (including EZ SpeedClic accessories)
Flexshaft attachment (225)
Instruction manual
Spacious and sturdy storage case with a removable accessory tray
Unique tool holder included for easy storage of your tool with your project
Product box length, 39.2 cm
Product box height, 10 cm
Product box width, 26.6 cm
Gross weight, 2,43 kg
Order number: F0133000HB
EAN Code: 8710364080830
£88.00
See Kit content
Dremel 3000
Multipupose cutting guide attachment (565)
Storage bag
Quick start guide
Test materials
Product box length, 25.7 cm
Product box height, 28.5 cm
Product box width, 8.6 cm
