Corded Tools
DREMEL® 3000 (3000-2/55)
Limited Edition Multi-Tool Kit - 40% Extra Value
Dremel 3000 - Quick. Compact. All-round.
Work on your home jobs and crafts for extended periods of time
Carve, engrave, rout, cut, sand, grind, sharpen, polish and clean. Tons of applications, thousands of projects
Mount your tool on the wall with the included tool holder and neatly wrap the cord around it
Give your jobs a perfect finish and try out new projects with the 55 included accessories
Dive into your DIY projects with this 40% extra value limited edition kit. Go from cutting to routing to polishing and more with just one tool. This kit contains the all-round Dremel 3000 Multi-Tool, 3 attachments to make the tool even more versatile and 55 interchangeable accessories to tackle many different home improvement projects. Store everything in the lightweight and spacious tool box and take it anywhere, easily, or mount your tool on the wall with the included tool holder. Get your 40% added value and begin any project immediately.
Technical details for DREMEL® 3000 (3000-2/55)
Technical specifications
Rated power input
130 W
Voltage
Weight
0,55 kg
Depth
No load speed
10.000 33.000 1/min
Battery technology
Speed setting
Variable
Accessory quick change system
Precision tip
Dual temperature
Removable cord
Drip control
Sound pressure
- 77,1 dB(A)
Sound power
- 88,1 dB(A)
Vibration
12,8 m/s²
Included accessories (57)
Overview of prices and Kit content
Order number: F0133000JH
EAN Code: 8710364067312
See Kit content
Dremel 3000
Detailer's Grip Attachment (577)
25 high quality Dremel accessories
Instruction manual
Soft bag
Product box length, 11 cm
Product box height, 32.5 cm
Product box width, 15.5 cm
Gross weight, 1,08 kg
Order number: F0133000LR
EAN Code: 8710364074471
See Kit content
Dremel 3000
55 high quality Dremel accessories (including EZ SpeedClic)
Flexible Shaft (225)
Cutting Guide attachment (565)
Shaping Platform Attachment (576)
Spacious and sturdy storage case
Instruction manual
Product box length, 39.5 cm
Product box height, 15.5 cm
Product box width, 18 cm
Gross weight, 2,11 kg
DREMEL® 3000 3 Star Kit (3000-05)
Order number: F0133000ME
EAN Code: 8710364077342
See Kit content
DREMEL® 3000
Unique tool holder included for easy storage of your tool with your project
Instruction Manual
Product box length, 30.5 cm
Product box height, 16.2 cm
Product box width, 8.8 cm
Gross weight, 1,07 kg
DREMEL® 3000 4 Star Kit (3000-3/55)
Order number: F0133000MJ
EAN Code: 8710364077380
See Kit content
DREMEL® 3000
Line & Circle Cutter (678)
Practical Dremel plastic tool box
Instruction Manual
Product box length, 38.5 cm
Product box height, 13.3 cm
Product box width, 17.5 cm
Gross weight, 2,23 kg
DREMEL® 3000 5 Star Kit (3000-5/75)
Order number: F0133000MP
EAN Code: 8710364077427
See Kit content
DREMEL® 3000
75 high quality Dremel accessories (including EZ SpeedClic)
Shaping Platform attachment (576)
Detailer's Grip attachment (577)
Line & Circle Cutter attachment (678)
Aluminum carry case
Instruction Manual
Product box length, 36.8 cm
Product box height, 18.7 cm
Product box width, 23.3 cm
Gross weight, 3,36 kg
DREMEL® 3000 (3000-05X)
Order number: F0133000NB
EAN Code: 8710364079643
See Kit content
DREMEL® 3000
Instruction Manual
Product box length, 8.8 cm
Product box height, 16 cm
Product box width, 30.5 cm
DREMEL® 3000 (3000-5/75X)
Order number: F0133000NL
EAN Code: 8710364079728
See Kit content
Dremel 3000
Aluminum carry case
Instruction Manual
Product box length, 23.3 cm
Product box height, 18.6 cm
Product box width, 36.5 cm
Gross weight, 3,23 kg
DREMEL® 3000 (3000-1/25)
Order number: F0133000JE
EAN Code: 8710364060894
£70.00
See Kit content
Dremel 3000
25 high quality Dremel accessories (including EZ SpeedClic accessories)
High quality Flex Shaft
Instruction manual
Product box length, 20.7 cm
Product box height, 11 cm
Product box width, 34 cm
Gross weight, 1,98 kg
Order number: F0133000LV
EAN Code: 8710364074518
£80.00
See Kit content
Dremel 3000
70 high quality Dremel accessories (including EZ SpeedClic)
Comfort Guard attachment (550)
Aluminum carry case
Instruction Manual
Product box length, 36.5 cm
Gross weight, 3,22 kg
Order number: F0133000LL
EAN Code: 8710364074433
£100.00
See Kit content
Dremel 3000
Instruction manual
Product box length, 25 cm
Product box width, 7.7 cm
Gross weight, 0,89 kg
Order number: F0133000NF
EAN Code: 8710364079681
£150.00
See Kit content
DREMEL® 3000
Flexshaft attachment (225)
Spacious and sturdy storage case with a removable accessory tray
Product box length, 17.5 cm
Product box width, 39 cm
Gross weight, 2,36 kg
DREMEL® 3000 Home Repair Project Kit (3000-3/105)
Order number: F0133000LE
EAN Code: 8710364072217
£200.00
See Kit content
Dremel 3000
105 high quality Dremel accessories (including EZ SpeedClic)
Home Renovation Project Booklet
Instruction Manual
Soft bag
Product box length, 22 cm
Product box height, 36.6 cm
Product box width, 10.9 cm
Gross weight, 1,84 kg
