Corded Tools
DREMEL® 3000 (3000-5/75X)
Limited Edition Multi-Tool Kit - 50% Extra Value
Dremel 3000 - Quick. Compact. All-round.
Carve, engrave, rout, cut, sand, grind, sharpen, polish and clean. Tons of applications, thousands of projects
Work on your home jobs and crafts for extended periods of time
Take on any DIY project with the 75 included cutting, grinding, sanding, polishing, and drilling accessories
Increase the versatility of the Multi-Tool with the 5 included attachments. Cut perfect lines and circles, work with the highest precision and more
Get ready to take on any DIY project. This kit features the sturdy Dremel 3000 Multi-Tool with 5 interchangeable attachments and 75 accessories including quick-change EZ SpeedClic accessories. The versatility of this kit allows you to cut, carve, sand, grind, polish and more. All with just one tool. Store and transport your full on kit easily with the strong aluminum tool box. Discover the Multi-Tool with the most added value now.
Technical details for DREMEL® 3000 (3000-5/75X)
Technical specifications
Rated power input
130 W
Voltage
Weight
0,55 kg
Depth
No load speed
10.000 33.000 1/min
Battery technology
Speed setting
Variable
Accessory quick change system
Precision tip
Dual temperature
Removable cord
Drip control
Sound pressure
- 77,1 dB(A)
Sound power
- 88,1 dB(A)
Vibration
12,8 m/s²
Included accessories (59)
Overview of prices and Kit content
Order number: F0133000JH
EAN Code: 8710364067312
See Kit content
Dremel 3000
Detailer's Grip Attachment (577)
25 high quality Dremel accessories
Instruction manual
Soft bag
Product box length, 11 cm
Product box height, 32.5 cm
Product box width, 15.5 cm
Gross weight, 1,08 kg
Order number: F0133000LR
EAN Code: 8710364074471
See Kit content
Dremel 3000
55 high quality Dremel accessories (including EZ SpeedClic)
Flexible Shaft (225)
Cutting Guide attachment (565)
Shaping Platform Attachment (576)
Spacious and sturdy storage case
Instruction manual
Product box length, 39.5 cm
Product box height, 15.5 cm
Product box width, 18 cm
Gross weight, 2,11 kg
DREMEL® 3000 3 Star Kit (3000-05)
Order number: F0133000ME
EAN Code: 8710364077342
See Kit content
DREMEL® 3000
Unique tool holder included for easy storage of your tool with your project
Instruction Manual
Product box length, 30.5 cm
Product box height, 16.2 cm
Product box width, 8.8 cm
Gross weight, 1,07 kg
DREMEL® 3000 4 Star Kit (3000-3/55)
Order number: F0133000MJ
EAN Code: 8710364077380
See Kit content
DREMEL® 3000
Line & Circle Cutter (678)
Practical Dremel plastic tool box
Instruction Manual
Product box length, 38.5 cm
Product box height, 13.3 cm
Product box width, 17.5 cm
Gross weight, 2,23 kg
DREMEL® 3000 5 Star Kit (3000-5/75)
Order number: F0133000MP
EAN Code: 8710364077427
See Kit content
DREMEL® 3000
75 high quality Dremel accessories (including EZ SpeedClic)
Shaping Platform attachment (576)
Detailer's Grip attachment (577)
Line & Circle Cutter attachment (678)
Aluminum carry case
Instruction Manual
Product box length, 36.8 cm
Product box height, 18.7 cm
Product box width, 23.3 cm
Gross weight, 3,36 kg
DREMEL® 3000 (3000-05X)
Order number: F0133000NB
EAN Code: 8710364079643
See Kit content
DREMEL® 3000
Instruction Manual
Product box length, 8.8 cm
Product box height, 16 cm
Product box width, 30.5 cm
Order number: F0133000NL
EAN Code: 8710364079728
See Kit content
Dremel 3000
Aluminum carry case
Instruction Manual
Product box length, 23.3 cm
Product box height, 18.6 cm
Product box width, 36.5 cm
Gross weight, 3,23 kg
DREMEL® 3000 (3000-1/25)
Order number: F0133000JE
EAN Code: 8710364060894
£70.00
See Kit content
Dremel 3000
25 high quality Dremel accessories (including EZ SpeedClic accessories)
High quality Flex Shaft
Instruction manual
Product box length, 20.7 cm
Product box height, 11 cm
Product box width, 34 cm
Gross weight, 1,98 kg
Order number: F0133000LV
EAN Code: 8710364074518
£80.00
See Kit content
Dremel 3000
70 high quality Dremel accessories (including EZ SpeedClic)
Comfort Guard attachment (550)
Aluminum carry case
Instruction Manual
Product box length, 36.5 cm
Gross weight, 3,22 kg
Order number: F0133000LL
EAN Code: 8710364074433
£100.00
See Kit content
Dremel 3000
Instruction manual
Product box length, 25 cm
Product box width, 7.7 cm
Gross weight, 0,89 kg
DREMEL® 3000 (3000-2/55)
Order number: F0133000NF
EAN Code: 8710364079681
£150.00
See Kit content
DREMEL® 3000
Flexshaft attachment (225)
Spacious and sturdy storage case with a removable accessory tray
Product box length, 17.5 cm
Product box width, 39 cm
Gross weight, 2,36 kg
DREMEL® 3000 Home Repair Project Kit (3000-3/105)
Order number: F0133000LE
EAN Code: 8710364072217
£200.00
See Kit content
Dremel 3000
105 high quality Dremel accessories (including EZ SpeedClic)
Home Renovation Project Booklet
Instruction Manual
Soft bag
Product box length, 22 cm
Product box height, 36.6 cm
Product box width, 10.9 cm
Gross weight, 1,84 kg
