Multi-Tools
NEW
Multi-Tools
NEW
Powerful all-rounder multi-tool - Get your DIY design piece done from start to finish with just one tool
  • Can be used with all Dremel multi-tool accessories and most attachments
  • Easily switch between light-duty and more powerful DIY tasks: engrave, carve, cut, polish, clean, sand and more
  • The variable speed settings supported with a wide range of accessories included enables you to craft with various materials
98 GBP
The Dremel 3000 is the versatile all-rounder multi-tool that gets you from start to finish. Perfect for DIY projects that require powerful and precise light duty finishing applied on various materials. Swap applications using the 25 accessories in no time: from carving, engraving, sanding, polishing to cutting and more. Together with the included Dremel Cutting Guide and Flexible Shaft the kit allows you to achieve neat results with ease.
Variable speed - 10.000 - 33.000 RPM: more comfortable and better control when handling.
130W motor: for optimal performance.
Soft grip: for reduced vibration and a better handling.
Rated power input
130 W
Voltage
Weight
0.55 kg
Depth
No load speed
10.000 33.000 1/min
Battery technology
Speed setting
Variable
Accessory quick change system
Sound pressure
77,1 dB(A)
Sound power
88,1 dB(A)
Vibration
12,8 m/s²
8710364080830
F0133000HB
User Manuals
Your Selection
Dremel Rotary Tool 3000 - Product Tool kit image
Order number: F0133000VK
EAN Code: 4053423072945
Product details
Dremel 3000 with 15 accessories
Order number: F0133000JB
EAN Code: 8710364060863
60 GBP
Product details
Related Media DREMEL® 3000 Limited Edition 2026
Order number: F0133000WD
EAN Code: 4053423067385
75 GBP
Product details
The Dremel 3000 Multi-Tool with 1 attachment, 25 accessories, a toolholder and a plactic case
Order number: F0133000JR
EAN Code: 8710364074693
88 GBP
Product details
