Multi-Tools
NEW
Multi-Tools
NEW
Multi-Tool – Quick. Compact. All-round.
- For all of your precision DIY projects: carve, engrave, rout, cut, sand, grind, sharpen, polish and clean
- Work on your projects for extended periods of time
- EZ Twist: Switch between applications within 1 or more projects easily
88 GBP
This kit includes the Dremel 3000 Multi-Tool, the high quality Dremel Flexible Shaft and 25 genuine Dremel accessories including EZ SpeedClic. All this is packed in a neatly organised case that includes a removable accessory tray and a tool holder which can be fixed to the wall and allows for easy wrapping of the tool's cord. This is a high value kit, offering you great value for money.
Variable speed - 10.000 - 33.000 RPM: more comfortable and better control when handling.
130W motor: for optimal performance.
Soft grip: for reduced vibration and a better handling.
Rated power input
130 W
Voltage
Weight
0,55 kg
Depth
No load speed
10.000 33.000 1/min
Battery technology
Speed setting
Variable
Accessory quick change system
Sound pressure
77,1 dB(A)
Sound power
88,1 dB(A)
Vibration
12,8 m/s²
8710364074693
F0133000JR
