Multi-Tools
Multi-Tools
A Champion’s Kit
- A fan favourite compact Multi-Tool trusted for carving, engraving, routing, cutting, sanding, grinding, sharpening, polishing and cleaning.
- Limited edition kit includes a mini trophy, 25 accessories, flex shaft and storage bag.
- Variable speed for full control, plus a soft grip for reduced vibration during longer work sessions.
Limited Edition, Unlimited Meaning
Dremel believes that everyone has moments worth recognising. This limited edition kit is made for anyone who wants to celebrate a moment in a more personal way. With the engrave ready mini trophy at the centre, this kit gives you a simple, hands on way to mark achievements big or small - whether it’s something you’ve accomplished yourself or something you want to celebrate in someone else.
The Iconic Tool Behind Every Triumph
Dremel 3000 is the true champion of quick, compact and versatile Multi-Tools. Its cordless design is built for precision across a wide range of applications, offering variable speed control from 10,000–35,000 RPM for carving, engraving, routing, cutting, sanding, grinding, sharpening, polishing and cleaning. Its soft grip construction reduces vibration for better handling during extended use, and it’s fully compatible with all Dremel Multi Tool accessories and attachments for maximum versatility.
A Champion’s Kit
This limited edition kit includes mini trophy ready to be personalised, 25 versatile accessories for polishing, engraving, sanding, cutting, grinding and drilling, giving you everything you need to start your next DIY project. The Flex Shaft Attachment (225) adds pencil like control for fine engraving and detailed work by bringing the tool’s power to a lightweight, easy to handle extension. All items fit neatly into a modular storage box for organised, grab and go convenience.
Variable speed - 10.000 - 33.000 RPM: more comfortable and better control when handling.
130W motor: for optimal performance.
Soft grip: for reduced vibration and a better handling.
