Get 15% on cordless Dremel tools for a limited time. Grab yours before they're gone!
Multi-Tools
NEW
Multi-Tools
NEW
The Original All-Round Multi-Tool
  • Trusted All-Round Multi‑Tool performance.
  • Curated kit of metalworking essentials for cutting, drilling and precision tasks.
  • Pen‑shaped Flex Shaft Attachment (225) for greater control on detailed work.
Limited Metal Edition
Specifically curated, this kit brings together the essentials to create a practical metalwork set up. The kit includes two Metal Cutting Wheels (SC456), a Precision Drill Bit Set (628) that includes 7 high-grade steel bits in various sizes, the Flex Shaft Attachment (225) and a Multi Chuck (4486) for quick and easy accessory changes. The pen shaped Flex Shaft Attachment delivers greater control for detailed tasks, making it easier to work accurately on smaller or more intricate projects.
Dremel 3000 is the true icon of quick, compact and versatile Multi-Tools. Its corded design is built for precision across a wide range of applications, offering variable speed control from 10,000–35,000 RPM for carving, engraving, routing, cutting, sanding, grinding, sharpening, polishing and cleaning. Its soft grip construction reduces vibration for better handling during extended use, and it’s fully compatible with all Dremel Multi Tool accessories and attachments for maximum versatility.
Enter a Versatile Ecosystem
The Dremel 3000 is compatible with the full range of Dremel Multi Tool accessories and attachments. While this edition is designed for metal work, the tool can be easily adapted for variety of tasks by simply changing accessories and attachments. Dremel’s portfolio supports 150+ accessories for a variety of applications: cutting, drilling, engraving, carving, routing, sanding, grinding, sharpening, polishing and cleaning.
Variable speed - 10.000 - 33.000 RPM: more comfortable and better control when handling.
130W motor: for optimal performance.
Soft grip: for reduced vibration and a better handling.
Rated power input
130 W
Voltage
Weight
0.55 kg
Depth
No load speed
10.000 - 35.000 1/min
Speed setting
Variable
Accessory quick change system
Sound pressure
80,1 dB(A)
Sound power
88,1 dB(A)
Vibration
12,8 ± 1,5 m/s²
4053423072945
F0133000VK
User Manuals
Your Selection
Dremel 3000 with 15 accessories
Order number: F0133000JB
EAN Code: 8710364060863
60 GBP
Product details
Related Media DREMEL® 3000 Limited Edition 2026
Order number: F0133000WD
EAN Code: 4053423067385
75 GBP
Product details
The Dremel 3000 Multi-Tool with 1 attachment, 25 accessories, a toolholder and a plactic case
Order number: F0133000JR
EAN Code: 8710364074693
88 GBP
Product details
Dremel 3000 2/25 Multi-Tool kit displayed with various attachments, a flex shaft, a carrying case, and some accessory bits
Order number: F0133000HB
EAN Code: 8710364080830
98 GBP
Product details
