Multi-Tools
Multi-Tools
Simply Easy.
  • The Dremel 3200 features a soft grip handle, ensuring precise control and reduced fatigue during use.
  • Offers a compact and user-friendly design, making handling effortless and delivering excellent results.
  • Gain smooth power control through the 130W motor.
90 GBP
Easy to use.
The Dremel 3200 features a soft grip handle that offers better control and reduces fatigue during use. This tool is designed for ease of use, with a compact and user-friendly design that delivers excellent results and effortless handling. When you open the Dremel 3200 box, you'll find a QR code. Just scan it, and you'll gain access to quick start guide videos, helping you start using it with ease. Plus, it's one of the smallest tools available, measuring only 19 cm in length and weighing just 580 grams, making it highly portable. Welcome to the Dremel 3200, where ease of use meets exceptional performance.
Effortless power made easy.
Mastering power has never been easier with the Dremel 3200, which boasts a robust 130W motor capable of handling all essential applications. Its speeds range from 10,000 to 33,000 RPM, providing versatile performance for your DIY tasks.
Seamless compatibility, easy expansion.
The Dremel 3200 offers seamless compatibility with the full range of Dremel accessories and attachments, enabling you to tackle a diverse array of applications, from precision cutting to fine sanding and beyond. Changing accessories has never been easier, thanks to the innovative EZ Twist nose cap, featuring a built-in key that eliminates the need for an additional tool.
Taking Sustainable Steps.
We're excited to announce a significant step in our sustainability efforts with the Dremel 3200, our first tool featuring a product housing made from over 55% recycled plastic (all components visible from the outside, excluding accessories). Additionally, the packaging is entirely polybag-free. Plus, with the Dremel 3200, you can replace the motor brush, extending the tool's lifespan. It's worth highlighting that Dremel is a proud member of the Bosch family, sharing the same sustainability vision and goals. We are dedicated to combining innovation with responsibility, striving for a more sustainable world. For more information on Bosch's mission to shape the future through sustainability, visit the following link: https://www.bosch.com/sustainability/. Choose Dremel 3200 for a tool that not only simplifies your projects but also contributes to a more sustainable future.
The Dremel 3200-1/90 kit
Unleash a wide array of applications with The Dremel 3200-1/90 Multi-Tool kit. This kit includes the Flexible Shaft (225) and 90 accessories for cleaning, polishing, grinding, sharpening, sanding, cutting, and drilling. Enhance your Dremel's versatility with the Flex Shaft (225) attachment, allowing for extended, comfortable use during tasks like engraving, polishing, and carving. The quick start guide and accessory information sheet ensure a smooth start with your new Dremel 3200 Multi-Tool.
Comfortable soft grip: better tool control & less hand fatigue.
Variable speed 10,000 to 33,000 RPM: Can adapt to a variety of tasks, offering precision, power, and efficiency.
Innovative EZ twist nose cap: for easy and fast accessory change.
Replaceable brushes: helping maximize your tool’s lifespan and efficiency.
Rated power input
130 W
Voltage
230 - 240 V
Weight
0.58 kg
Depth
No load speed
10.000 - 35.000 1/min
Speed setting
Variable
Accessory quick change system
Sound pressure
79 dB(A)
Sound power
87 dB(A)
Vibration
12,1 ± 1,5 m/s²
4053423254303
F0133200JB
User Manuals
Dremel Multi-Tool 3200 with 1 attachment and 90 accessories
Delivery details
  • Dremel 3200
  • 90 Dremel Accessories
  • DREMEL® Flexible Shaft (225)
  • Instruction manual
  • Accessory sheet
  • Product box length, 22 cm
  • Product box height, 27.7 cm
  • Product box width, 5.2 cm
  • Gross weight, 1.37 kg
90 GBP
