Printers
DREMEL® 3D PETG Filament Translucent 750gr (PETG-TRA-01)
The Dremel 3D printer melts and prints the 1.75mm PETG filament layer by layer no thicker than a sheet of paper to provide a very smooth surface for your creation. Ideal for printing flexible and heat resistant 3D objects ensuring excellent layer adhesion and low chances of shrinkage and warping.
  • RFID filament recognition tag - Printer automatically adjusts settings by reading the filament RFID tag
  • Provides a finishing durable like ABS and easy to print like PLA
  • Ensures excellent layer adhesion and low chances of shrinkage and warping which brings printing with ease
Dremel PETG filament has been specifically engineered for optimal printing with your Dremel 3D Printer 3D45. PETG is a common polymer, which is durable like ABS and easy to print like PLA. Its strength, flexibility and temperature resistance makes it ideal for mechanical parts. PETG filament has excellent layer adhesion and low chances of shrinkage and warping which brings printing with ease. The Dremel PETG filament spool is equipped with a RFID tag that allows the Dremel 3D45 to read the type of filament and adjusts the 3D printer settings accordingly.
Technical details for DREMEL® 3D PETG Filament Translucent 750gr (PETG-TRA-01)
Technical specifications
Weight
0.75 kg
PETG - Only use with DREMEL® DigiLab 3D Printer 3D45
Color
DF70-01-Natural White/Translucent
Material Diameter
1.75 mm
180,0 mm
180,0 mm
Height
54,0 mm
Package Contents
1 piece
Suitable Dremel devices
2615PG12JA
8710364081882
Variations
Similar Accessories (14)
Delivery details: DREMEL® 3D PETG Filament Translucent 750gr (PETG-TRA-01)
1x DREMEL® 3D PETG Filament Translucent
Product box length, 18.5 cm
Product box height, 18.5 cm
Product box width, 6 cm
Gross weight, 0,80 kg
2615PG12JA
8710364081882
Recommended products:
£1,600.00* RRP incl. VAT
