Printers
DREMEL® 3D PLA Filament Green 750gr (PLA-GRE-01)
The Dremel 3D printer melts and prints the 1.75mm PLA filament layer by layer no thicker than a sheet of paper to provide a very smooth surface for your creation. It is plant-based and recyclable. Perfect for printing your own created 3D objects or prototypes.
  • Plant-based and recyclable
  • RFID filament recognition tag - Printer automatically adjusts settings by reading the filament RFID tag
  • Provides a very smooth surface for your 3D creation
Dremel PLA filament has been specifically engineered for optimal printing with your Dremel 3D Printer. PLA is a thermal plastic that softens and melts when it’s heated, building your designs strand by strand and layer by layer. The PLA has been designed to melt at a temperature compatible with the Dremel 3D Printer, producing a stable, strong object with a high quality finish.
Technical details for DREMEL® 3D PLA Filament Green 750gr (PLA-GRE-01)
Technical specifications
Weight
0.75 kg
PLA
Material Diameter
1.75 mm
180,0 mm
180,0 mm
Height
54,0 mm
Suitable Dremel devices
2615PL07JA
8710364081783
Variations
Similar Accessories (12)
Delivery details: DREMEL® 3D PLA Filament Green 750gr (PLA-GRE-01)
1x DREMEL® 3D PLA Filament Green
Product box length, 18.5 cm
Product box height, 18.5 cm
Product box width, 6 cm
Gross weight, 0,80 kg
2615PL07JA
8710364081783
Recommended products:
DREMEL® DigiLab 3D Printer 3D40
£1,150.00* RRP incl. VAT
DREMEL® DigiLab 3D Printer 3D45
£1,600.00* RRP incl. VAT
