Corded Tools
DREMEL® 4000 (4000-4/55)
Maker Kit
Limited edition powerful Multi-tool for everyday use
Tackle your precision carving, engraving, routing, cutting, sanding, grinding, sharpening, polishing and cleaning projects with just one tool
Experience maximum control and precision with the most variable rotary speed (5.000 – 35.000)
Comes in a spacious and sturdy storage case with a removable accessory tray for convenient storage
Increase the versatility of your Multi-Tool with the 4 attachments and 45 accessories
Bring utmost precision to your project using this exclusive kit. Which includes the powerful Dremel 4000 with 4 interchangeable attachments and 57 accessories including EZ SpeedClic accessories. This versatile kit allows for you to cut, carve, sand, grind, polish and more. Use the accessory storage solution to have all your necessary accessories stored neatly making it easy to pick the right accessory for the job.
Example of usage
Technical details for DREMEL® 4000 (4000-4/55)
Technical specifications
Rated power input
Voltage
Weight
0,66 kg
4.1 cm
Depth
4.3 cm
No load speed
5.000 35.000 1/min
Speed setting
Fully variable
Accessory quick change system
Precision tip
Dual temperature
Removable cord
Drip control
Sound pressure
78 dB(A)
Sound power
89 dB(A)
Vibration
11,4 m/s²
Included Accessories (55)
Overview of prices and Kit content
Order number: F0134000JE
EAN Code: 8710364048205
Dremel 4000
65 high quality Dremel accessories in Mini Accessory Case (including EZ SpeedClic starter set)
High quality Flex Shaft
Pencil grip nose cap
Line & Circle Cutter
Shaping Platform
Detailer’s Grip
Instruction manual
Spacious and sturdy storage case
Product box length, 26.8 cm
Product box height, 39 cm
Product box width, 10 cm
Gross weight, 2,70 kg
Order number: F0134000UB
EAN Code: 8710364080694
DREMEL® 4000
57 high quality Dremel accessories
Flexshaft attachment (225)
Line & Circle Cutter attachment (678)
Cutting Guide attachment (565)
Detailer's Grip attachment (577)
Aluminum carry case
Accessory holder
Accessory information sheet
Instruction manual
Product box length, 23.3 cm
Product box height, 18.6 cm
Product box width, 36.5 cm
Gross weight, 3,40 kg
DREMEL® 4000 (4000-1/45X)
Order number: F0134000UN
EAN Code: 8710364081462
Dremel 4000
45 high quality Dremel accessories (including EZ SpeedClic starter set)
Detailers grip
Plastic toolholder
2x Accessory holder
Instruction manual
Plastic Tool case
