Corded Tools
Multi-Tool – Strong. Dynamic. Maximum control.
Strong and dynamic Multi-Tool for everyday use
Tackle your precision carving, engraving, routing, cutting, sanding, grinding, sharpening, polishing and cleaning projects with just one tool
Experience maximum control and precision with the most variable rotary speed (5.000 – 35.000)
Comes in a spacious and sturdy storage case with a removable accessory tray for convenient storage.
2 year warranty
This Dremel kit includes the high performance 4000 Multi-Tool with the new EZ Twist Nose Cap. This means no wrench is needed anymore when changing accessories. It comes in a neatly organised case that includes a removable accessory tray and a tool holder which can be fixed to the wall and allows for easy wrapping of the tool's cord. This practical carrying case also contains the Flex Shaft, the Line & Circle Cutter, the detailer’s grip and the shaping platform attachment. Furthermore 65 original Dremel accessories are included.
Example of usage
Technical details for DREMEL® 4000 (4000-4/65 EZ)
Technical specifications
Rated power input
Voltage
Weight
0,66 kg
4.1 cm
Depth
4.3 cm
No load speed
5.000 35.000 1/min
Battery technology
Dual temperature
n.a. °C
Speed setting
Fully Variable
Accessory quick change system
Precision tip
Dual temperature
Removable cord
Drip control
Sound pressure
78 dB(A)
Sound power
89 dB(A)
Vibration
11,4 m/s²
Included Accessories (51)
Overview of prices and Kit content
Order number: F0134000JB
EAN Code: 8710364048175
£100.00
See Kit content
Dremel 4000
45 high quality Dremel accessories (including EZ SpeedClic starter set)
High quality Flex Shaft (225)
Instruction manual
Soft bag
Product box length, 25.8 cm
Product box height, 28.7 cm
Product box width, 8.7 cm
Gross weight, 1,79 kg
Order number: F0134000JR
EAN Code: 8710364074730
£130.00
See Kit content
Dremel 4000
65 high quality Dremel accessories in Mini Accessory Case (including EZ SpeedClic starter set)
Flexshaft attachment (225)
Pencil grip nose cap
Line & Circle Cutter attachment (678)
Shaping Platform attachment (576)
Detailer's Grip attachment (577)
Instruction manual
Spacious and sturdy storage case with a removable accessory tray
Unique tool holder included for easy storage of your tool with your project
Product box length, 398.2 cm
Product box height, 10 cm
Product box width, 26.6 cm
Gross weight, 2,82 kg
Order number: F0134000KF
EAN Code: 8710364057955
£210.00
See Kit content
Dremel 4000
128 high quality Dremel accessories
Right Angel attachment (575)
Cutting Guide attachment (565)
Instruction manual
Aluminum carry case
Product box length, 43.7 cm
Product box height, 23.6 cm
Product box width, 24.3 cm
Gross weight, 6,00 kg
