Retired Products
Retired Products
120.31 GBP
This Dremel kit includes the high performance 4000 Multi-Tool with the new EZ Twist Nose Cap. This means no wrench is needed anymore when changing accessories. It comes in a practical carrying case which contains the Flex Shaft, the Line & Circle Cutter, the detailer’s grip and the shaping platform attachment. Furthermore 65 original Dremel accessories are included.
High power 175W motor for high performance
Full variable speed control (5.000-35.000 RPM) for maximum precision
Electronic feedback for enhanced torque and performance
Rated power input
Voltage
Weight
0.66 kg
4.1 cm
Depth
4.3 cm
No load speed
5.000 - 35.000 1/min
Battery technology
Speed setting
Fully Variable
Accessory quick change system
Sound pressure
77,9 dB(A)
Sound power
88,9 dB(A)
Vibration
2,6 - 11,4 m/s²
8710364048205
F0134000JE
