Retired Products
Retired Products
Multi-Tool – Strong. Dynamic. Maximum control.
  • Strong and dynamic Multi-Tool for everyday use
  • Tackle your precision carving, engraving, routing, cutting, sanding, grinding, sharpening, polishing and cleaning projects with just one tool
  • Experience maximum control and precision with the most variable rotary speed (5.000 – 35.000)
144.99 GBP
This Dremel kit includes the high performance 4000 Multi-Tool with the new EZ Twist Nose Cap. This means no wrench is needed anymore when changing accessories. It comes in a neatly organised case that includes a removable accessory tray and a tool holder which can be fixed to the wall and allows for easy wrapping of the tool's cord. This practical carrying case also contains the Flex Shaft, the Line & Circle Cutter, the detailer’s grip and the shaping platform attachment. Furthermore 65 original Dremel accessories are included.
High power 175W motor for high performance
Full variable speed control (5.000-35.000 RPM) for maximum precision
Electronic feedback for enhanced torque and performance
Rated power input
Voltage
Weight
0.66 kg
4.1 cm
Depth
4.3 cm
No load speed
5.000 - 35.000 1/min
Battery technology
Dual temperature
n.a. °C
Speed setting
Fully Variable
Accessory quick change system
Sound pressure
78 dB(A)
Sound power
89 dB(A)
Vibration
11,4 m/s²
8710364074730
F0134000JR
User Manuals
Your Selection
Dremel Multi-Tool 400 with 4 attachments, 65 accessories and a grey case with a blue Dremel logo
Order number: F0134000JE
EAN Code: 8710364048205
120.31 GBP
Product details
DREMEL® 4000 (4000-4/55)
Order number: F0134000UB
EAN Code: 8710364080694
139.99 GBP
Product details
Dremel 3000 with a case,  a Dremel detailer's grip attachement, accessory and tool holder with some Dremel accessories
DREMEL® 4000 (4000-1/45X)
Order number: F0134000UN
EAN Code: 8710364081462
89.98 GBP
Product details
Dremel 4000 with 1 attachment and 45 accessories
Order number: F0134000JB
EAN Code: 8710364048175
114.99 GBP
Product details
Dremel 4000 with 6 attachments and 128 accessories
Order number: F0134000KF
EAN Code: 8710364057955
230 GBP
Product details
