Retired Products
DREMEL® 4000 (4000-4/55)
Retired Products
Maker Kit
- Limited edition powerful Multi-tool for everyday use
- Tackle your precision carving, engraving, routing, cutting, sanding, grinding, sharpening, polishing and cleaning projects with just one tool
- Experience maximum control and precision with the most variable rotary speed (5.000 – 35.000)
139.99 GBP
Bring utmost precision to your project using this exclusive kit. Which includes the powerful Dremel 4000 with 4 interchangeable attachments and 57 accessories including EZ SpeedClic accessories. This versatile kit allows for you to cut, carve, sand, grind, polish and more. Use the accessory storage solution to have all your necessary accessories stored neatly making it easy to pick the right accessory for the job.
High power 175W motor for high performance
Full variable speed control (5.000-35.000 RPM) for maximum precision
Electronic feedback for enhanced torque and performance
Rated power input
Voltage
Weight
0.66 kg
4.1 cm
Depth
4.3 cm
No load speed
5.000 - 35.000 1/min
Speed setting
Fully variable
Accessory quick change system
Sound pressure
78 dB(A)
Sound power
89 dB(A)
Vibration
11,4 m/s²
8710364080694
F0134000UB
