Retired Products
DREMEL® 4000 (4000-1/45X)
Retired Products
Dremel Advanced Kit
  • Work on a wide range of materials with this limited edition kit that has 20% added value.
  • Have maximum power and precision with the Dremel 4000 Multi-Tool that has the most variable rotary speed (5,000 – 35,000 RPM).
  • With the full set of 45 Dremel accessories you can easily go from cutting to grinding and from cleaning to sanding with just one Multi-Tool.
89.98 GBP
Master your DIY projects and take your skills to the next level with the Dremel Advanced Kit. The powerful Dremel 4000 Multi-Tool allows you to work better and faster on any kind of task. This versatile kit with 45 included accessories enables you to easily go from cutting to grinding to cleaning to polishing with just one Multi-Tool. Have total control over your project with the included Detailer’s Grip Attachment. Stay organised with the sturdy toolbox, a tool holder and an easy storage solution for the accessories. You can tackle any kind of DIY home improvement project with this versatile kit.
High power 175W motor for high performance
Full variable speed control (5.000-35.000 RPM) for maximum precision
Electronic feedback for enhanced torque and performance
Rated power input
Voltage
Weight
0.66 kg
4.1 cm
Depth
4.3 cm
No load speed
5.000 35.000 1/min
Battery technology
Speed setting
Fully Variable
Accessory quick change system
Sound pressure
78 dB(A)
Sound power
89 dB(A)
Vibration
11,4 m/s²
8710364081462
F0134000UN
Your Selection
Dremel Multi-Tool 400 with 4 attachments, 65 accessories and a grey case with a blue Dremel logo
Order number: F0134000JE
EAN Code: 8710364048205
120.31 GBP
Product details
DREMEL® 4000 (4000-4/55)
Order number: F0134000UB
EAN Code: 8710364080694
139.99 GBP
Product details
Dremel 4000 with 1 attachment and 45 accessories
Order number: F0134000JB
EAN Code: 8710364048175
114.99 GBP
Product details
The Dremel 4000 Multi-Tool with 4 attachments, 64 accessories, a toolholder and a plactic case
Order number: F0134000JR
EAN Code: 8710364074730
144.99 GBP
Product details
Dremel 4000 with 6 attachments and 128 accessories
Order number: F0134000KF
EAN Code: 8710364057955
230 GBP
Product details
