Corded Tools
Multi-Tool – Strong. Dynamic. Maximum control.
Platinum Edition: the most versatile corded Multi-Tool kit with 128 accessories and 6 attachments included.
Strong and dynamic Multi-Tool for everyday use
Experience maximum control and precision with the most variable rotary speed (5.000 – 35.000)
Packed in a sturdy aluminum tool case for safe transportation and easy storage
The Dremel 4000 Platinum Edition is the ultimate Dremel Multi-Tool kit. Besides the top of the line Dremel 4000 with EZ Twist Nose Cap you get 6 useful attachments and 128 genuine Dremel accessories all packed in a high quality aluminum tool case. With this supreme kit even the most demanding craftsman will be satisfied.
Example of usage
Technical details for DREMEL® 4000 Platinum Edition (4000-6/128)
Technical specifications
Rated power input
Voltage
Weight
0,66 kg
4.1 cm
Depth
4.3 cm
No load speed
5.000 - 35.000 1/min
Battery technology
No load speed (3)
Speed setting
Fully Variable
Accessory quick change system
Precision tip
Dual temperature
Removable cord
Drip control
Sound pressure
78 dB(A)
Sound power
89 dB(A)
Vibration
11,4 m/s²
Included Accessories (112)
Overview of prices and Kit content
Order number: F0134000JB
EAN Code: 8710364048175
£100.00
Dremel 4000
45 high quality Dremel accessories (including EZ SpeedClic starter set)
High quality Flex Shaft (225)
Instruction manual
Soft bag
Product box length, 25.8 cm
Product box height, 28.7 cm
Product box width, 8.7 cm
Gross weight, 1,79 kg
Order number: F0134000JR
EAN Code: 8710364074730
£130.00
Dremel 4000
65 high quality Dremel accessories in Mini Accessory Case (including EZ SpeedClic starter set)
Flexshaft attachment (225)
Pencil grip nose cap
Line & Circle Cutter attachment (678)
Shaping Platform attachment (576)
Detailer's Grip attachment (577)
Instruction manual
Spacious and sturdy storage case with a removable accessory tray
Unique tool holder included for easy storage of your tool with your project
Product box length, 398.2 cm
Product box height, 10 cm
Product box width, 26.6 cm
Gross weight, 2,82 kg
Order number: F0134000KF
EAN Code: 8710364057955
£210.00
Dremel 4000
128 high quality Dremel accessories
Right Angel attachment (575)
Cutting Guide attachment (565)
Instruction manual
Aluminum carry case
Product box length, 43.7 cm
Product box height, 23.6 cm
Product box width, 24.3 cm
Gross weight, 6,00 kg
