Multi-Tools
Unlimited power, ultimate experience
High performance for high-duty tasks. Dremel 4250 is the highest performing corded tool in the Dremel line up.
Cut, drill, grind, sand, polish and engrave with the 45 included high quality Dremel accessories.
The case allows you to carry and store all accessories and attachments easily. For frequent use, you can use the wall-mount.
Extend your usage to creative projects with Flexible Shaft (225).
Maximum power for your high-duty projects. Tackle the toughest presicion jobs with this complete 4250 kit including 45 accessories, 3 attachments and two storage solutions. Carry your Dremel® 4250 Multi-Tool around in its light-weight case or hang it to the wall with the tool holder to quickly access it.
Example of usage
Technical details for DREMEL® 4250 (4250-3/45)
Technical specifications
Rated power input
Voltage
Weight
0,60 kg
Depth
No load speed
5.000 35.000 1/min
Accessory quick change system
Precision tip
Dual temperature
Removable cord
Drip control
Sound pressure
72,5 - 72,5 dB(A)
Sound power
83,5 - 83,5 dB(A)
Vibration
14,1 ± 1,5 m/s²
Overview of prices and Kit content
DREMEL® 4250 (4250-35)
Order number: F0134250JB
EAN Code: 8710364082582
£105.00
Dremel 4250 Multi-tool
35 High Quality Dremel Accessories
Accessory information sheet
Multi-functional fabric bag
Manual
Product box length, 23 cm
Product box height, 10 cm
Product box width, 34 cm
Gross weight, 2,70 kg
Order number: F0134250JG
EAN Code: 8710364082612
£145.00
45 High Quality Dremel Accessories
Flexshaft attachment (225)
Line & Circle Cutter attachment (678)
Comfort guard (550)
Spacious and sturdy storage case with a removable accessory tray
Unique tool holder included for easy storage of your tool with your projects
Instruction Manual
Accessory Specification Sheet
Product box length, 271 cm
Product box width, 39.6 cm
DREMEL® 4250 (4250-6/128)
Order number: F0134250JL
EAN Code: 8710364082667
£215.00
128 high quality Dremel accessories
Detailer's Grip attachment (577)
Right Angel attachment (575)
Cutting Guide attachment (565)
Shaping Platform attachment (576)
Instruction manual
Accessory information Sheet
Deluxe Aluminum carry case with drawer
Product box length, 44 cm
Product box height, 24.5 cm
Product box width, 24 cm
Gross weight, 5,50 kg
