Corded Tools
DREMEL® 4250 (4250-6/128)
Unlimited power, ultimate experience
The highest performing corded Multi-Tool to tackle high-duty projects and tough applications for unlimited period of time.
Most inclusive Dremel 4250 kit; 128 accessories and 6 attachments will allow you to unlock the full Dremel experience
Bring precision to your toughest jobs and ease to your creative projects.
Keep all your accessories and attachments organised with the spacious and sturdy storage case.
Dremel® 4250 gives you ultimate experience with unlimited power. Cut, carve, sand, grind, polish, engrave and do much more with this most exclusive kit of Dremel 4250. It includes 128 accessories and 6 attachments for all kinds off applications and DIY projects. Sturdy storage case will allow you to carry your tool easily and keep all accessories and attachments neatly. From the toughest functional jobs to detailed creative projects, this kit will support you across a broad range of applications.
Example of usage
Technical details for DREMEL® 4250 (4250-6/128)
Technical specifications
Rated power input
Voltage
Weight
0,60 kg
Depth
No load speed
5.000 35.000 1/min
Accessory quick change system
Precision tip
Dual temperature
Removable cord
Drip control
Sound pressure
72,5 - 72,5 dB(A)
Sound power
83,5 - 83,5 dB(A)
Vibration
14,1 ± 1,5 m/s²
Included Accessories (112)
Overview of prices and Kit content
DREMEL® 4250 (4250-35)
Order number: F0134250JB
EAN Code: 8710364082582
£99.00
Dremel 4250 Multi-tool
35 High Quality Dremel Accessories
Accessory information sheet
Multi-functional fabric bag
Manual
Product box length, 23 cm
Product box height, 10 cm
Product box width, 34 cm
Gross weight, 2,70 kg
Order number: F0134250JG
EAN Code: 8710364082612
£134.99
45 High Quality Dremel Accessories
Flexshaft attachment (225)
Line & Circle Cutter attachment (678)
Comfort guard (550)
Spacious and sturdy storage case with a removable accessory tray
Unique tool holder included for easy storage of your tool with your projects
Instruction Manual
Accessory Specification Sheet
Product box length, 271 cm
Product box width, 39.6 cm
Order number: F0134250JL
EAN Code: 8710364082667
£199.99
128 high quality Dremel accessories
Detailer's Grip attachment (577)
Right Angel attachment (575)
Cutting Guide attachment (565)
Shaping Platform attachment (576)
Instruction manual
Accessory information Sheet
Deluxe Aluminum carry case with drawer
Product box length, 44 cm
Product box height, 24.5 cm
Product box width, 24 cm
Gross weight, 5,50 kg
