Multi-Tools
DREMEL® 4250 (4250-35)
Multi-Tools
Unlimited power, ultimate experience
- High performance corded Multi-Tool with uninterrupted power.
- Start cutting, sanding, polishing, grinding and engraving right away.
- 35 accessories including EZ SpeedClic.
107 GBP
The Dremel® 4250 is where maximum power meets high-quality and durable design. This kit comes with the Dremel 4250 Multi-Tool, 35 accessories and a fabric bag, perfect for your tough DIY projects.
Experience maximum corded power of the 175W motor allowing you to work on your heavy-duty DIY projects that require precision.
Compatible with all Dremel accessories which can be switched quickly and easily thanks to the EZ Twist nose caps integrated wrench.
With its intuitive button placement and rubber soft grip you will be in total control over your demanding projects.
Rated power input
Voltage
Weight
0.60 kg
Depth
No load speed
5.000 35.000 1/min
Speed setting
Fully Variable Speed
Accessory quick change system
Sound pressure
- 72,5 dB(A)
Sound power
- 83,5 dB(A)
Vibration
14,1 ± 1,5 m/s²
8710364082582
F0134250JB
