Multi-Tools
Multi-Tools
Unlimited power, ultimate experience
- High performance for high-duty tasks. Dremel 4250 is the highest performing corded tool in the Dremel line up.
- Cut, drill, grind, sand, polish and engrave with the 45 included high quality Dremel accessories.
- The case allows you to carry and store all accessories and attachments easily. For frequent use, you can use the wall-mount.
Maximum power for your high-duty projects. Tackle the toughest presicion jobs with this complete 4250 kit including 45 accessories, 3 attachments and two storage solutions. Carry your Dremel® 4250 Multi-Tool around in its light-weight case or hang it to the wall with the tool holder to quickly access it.
Experience maximum corded power of the 175W motor allowing you to work on your heavy-duty DIY projects that require precision.
Compatible with all Dremel accessories which can be switched quickly and easily thanks to the EZ Twist nose caps integrated wrench.
With its intuitive button placement and rubber soft grip you will be in total control over your demanding projects.
