Corded Tools
Multi-Tool - Luminous. Limitless. Max power.
Ideal for working on any material, soft or hard
Carving, engraving, routing, cutting, sanding, grinding, sharpening, polishing and cleaning. A constant stream of different projects you can tackle
Get the best results with the LED light at the front of the tool. Work with the greatest precision, even in dark areas
Simply swap the accessory and proceed to the next step of your project
£140.00*
RRP incl. VAT
Endless possibilities - one tool. From sanding to grinding, and routing to cutting; this Multi-Tool produces power from job to job. Electronic feedback gives additional power when needed to maintain maximum performance when working with both soft and hard materials. You are always in perfect control of your projects. Even when working in awkward angles, tight spaces and dark areas. The 360° adjustable LED light at the front of the tool allows you to clearly see everything that you’re doing, so you can work with the greatest precision. Simply insert any accessory that fits your project and you’re ready to go.
Example of usage
Technical details for DREMEL® 4300 (4300-3/45EZ)
Technical specifications
Rated power input
Voltage
Weight
0,66 kg
24 cm
4.1 cm
Depth
4.3 cm
No load speed
5.000 - 35.000 1/min
Battery technology
No load speed (3)
Speed setting
Fully Variable
Accessory quick change system
Multi Chuck
Precision tip
Dual temperature
Removable cord
Drip control
Sound pressure
74,4 dB(A)
Sound power
85,4 dB(A)
Vibration
18 m/s²
Included Accessories (41)
Delivery details: DREMEL® 4300 (4300-3/45EZ)
Dremel 4300
45 high quality Dremel accessories
Flexible Shaft (225)
Cutting guide (565)
Line & Circle Cutter (678)
Spacious and sturdy storage case with a removable accessory tray
Pivot Light
Sanding / Grinding Guide
Product box length, 39.2 cm
Product box height, 10 cm
Product box width, 26.6 cm
Gross weight, 2,73 kg
F0134300JB
8710364079605
8710364079605
